2005 G35 Sedan Aftermarket Navi/Amp/Sub Help
Old Feb 12, 2010 | 11:31 PM
dopeyx27's Avatar
Hey everyone,
Ive been searching for a couple of hours but I couldnt seem to find the answer to my question. I want to put aftermarket double din Navigation in my 05 g35 sedan (Avic z1) with the steering wheel remote adapter, and bluetooth module. I also wanted to wire my RF amp and dual L7s. The car has the bose system and I understand that you need a special harness in order to get it to work. What I want to know is what harnesses are needed to get this to work. I found the 70-7551 from Metra but Im not sure if I could connect my aftermarket amp/subwoofers to that. I dont want to lose any of the factory speakers/subs so Im hoping that the 70-7551 harness would do.
So far I have the following:
  • JDM DD KIT with DUAL AC
  • AVIC Z1 DD NAVI
  • SE Steering wheel adapter
  • Z1 Bluetooth module
  • Rockford Fosgate Amp
  • Kicker L7 (2)
So just to sum it up, I want to be able to utilize all of the factory speakers/subs and also be able to wire up my aftermarket amp/sub without having to do anything drastic.
All help is appreciated.
Thanks!
Alan
Old Feb 13, 2010 | 12:52 PM
BuckeyeInMI's Avatar
Try posting this in the Audio section. But from what I've found, you should consider replacing the door speakers as well, especially considering they're almost 5 years old.
Old Feb 13, 2010 | 02:01 PM
NjMatteSedan's Avatar
This will be moved to the audio section fyi, +1 on replacing the bose speakers, tweeters and also aftermarket sub
Old Feb 13, 2010 | 03:22 PM
NFSP G35's Avatar
? = 2B || !2B
Ditch the door speakers. They're crap. Even basic Infinity Ref are better.
laksjd84
Feb 28, 2026 01:58 PM
lemmy999
Jul 25, 2015 12:13 PM
tehmoonrulz
Jul 19, 2015 10:44 PM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
Scredeur4
Steering & Suspension
Jul 17, 2015 06:30 AM
