What else?
Old Feb 28, 2010 | 01:10 AM
kevin3751's Avatar
What else?
I think im going to get the Eibach Pro Kit to lower my car. I have stock suspension, so what ELSE would i NEED since im going to lower it . (I have 20s).
Old Feb 28, 2010 | 01:11 AM
4drmadness's Avatar
alignment thats all.
Old Feb 28, 2010 | 09:43 AM
kevin3751's Avatar
no need for new shocks/struts, etc?
Old Feb 28, 2010 | 10:07 AM
davidxu's Avatar
do an alignment, then see if you need camber kits or not.
Old Feb 28, 2010 | 10:10 AM
Mustang5L5's Avatar
WOuldn't be a bad idea...along with camber kits.
Some will argue that you don't need them, but if you are gonna lower your car, might as well do it correctly IMHO.
Old Feb 28, 2010 | 11:36 AM
4drmadness's Avatar
yes, new shocks would be a good idea. Get some tokico blue. I believe the eibach only drops the car an inch, so camber kits are not necessary imo
Old Feb 28, 2010 | 11:41 AM
kevin3751's Avatar
How much do the tokico blue usually run?...and Eibach Pro is only a 1" drop..but i like it because it is more of an even drop than the tein s techs...so maybe if i want to go lower i should go with Eibach Sportline because it drops more and is still even...
Old Feb 28, 2010 | 12:02 PM
iTzTeddy's Avatar
I read somehwere that the stock struts will wear out if lowered so you're going to need to replace the strock struts with sports struts if it isnt already.
Old Feb 28, 2010 | 12:21 PM
NjMatteSedan's Avatar
Tokiko blues are like $270 I got tein s tech and is like 90% even, you can fit 1 finger in the back and 2 fingers in the front but I have subwoofers
