WTF.. car alarm went of randomly in my garage
Old Mar 3, 2010 | 03:03 AM
0MGHI2U's Avatar
Angry WTF.. car alarm went of randomly in my garage
ok so it has happened a few times.. i keep my car in the garage at all times and i just woke up from my car alarm going off on its own.. wtf is going on? i did a search and came up with nothing.. anyone?
Old Mar 3, 2010 | 03:12 AM
There's a ghost in there
Old Mar 3, 2010 | 03:20 AM
TIAN's Avatar
Hold The Line
My compustar did the same thing and I stripped it out.
Old Mar 3, 2010 | 03:39 AM
0MGHI2U's Avatar
iseechriss: haha. ******* basturd better get out.. LOL
any known issues about this and fixes?
Old Mar 3, 2010 | 07:17 AM
G35pwrd's Avatar
Alarm.... pretty vague. Factory, aftermarket, company, features..... this information can probably get you a better answer.
Old Mar 3, 2010 | 07:50 AM
mcaron's Avatar
used to happen to me too. i just unpluged my hood sensor and it stoped doing it
Old Mar 3, 2010 | 07:57 AM
SedanManBen's Avatar
it really depends if it's aftermarket or not. If it's not aftermarket, you probably have a bad door sensor (or some sort of sensor). I've had this happen on my car, except my effects were different. The car is set to automatically re-lock itself after 60 seconds if you unlock the car and don't open a door... so because the car didn't know the door was being opened.. it locked my keys in the car while it was running -_- .... I had started it to let it warm up.
I'd look into this being a possibility.. if there is a faulty sensor, that would likely cause the alarm to go off randomly.
Old Mar 3, 2010 | 10:53 AM
Playa24_7's Avatar
My car did some really weird things recently, like when I tried to start the car the horn would just start blaring like the alarm was going off. I found out my battery needed to be replaced. Apparently once the battery goes below a certain voltage, according to the guy at Inifniti, it resets a bunch of things on the car. Once we replaced it all the problems were gone. Not sure if that's it for you, but who knows.
Old Mar 3, 2010 | 11:05 AM
blazium's Avatar
^+1 I second that. Test your battery
Old Mar 3, 2010 | 11:13 AM
03SilverGSedan's Avatar
I just bought an 03 Sedan and mine is doing the same thing. It had a viper alarm on it but I'm using the factory alarm instead. Not that I dont like Viper, I just dont know how it was installed and don't trust what other people may have done with the wiring.
I will try the hood sensor. Is it an obvious hood pin or is it hidden somewhere?
Old Mar 3, 2010 | 11:40 AM
0MGHI2U's Avatar
shoot sorry guys.. i have the factory alarm on my 06 coupe
Old Mar 3, 2010 | 11:53 AM
05_SkylineSedan's Avatar
20 Year Member
My garage is under the house and I keep the fob in my pocket... Just working around the house I've occasionally found the G's windows all lowered and actually set off the alarm the other day because the buttons were getting pressed. Don't sit on your fob!
Old Mar 3, 2010 | 07:41 PM
0MGHI2U's Avatar
ok bought a new battery and disconnected the hood sensor.. lets hope this fixes the issue
Old Mar 3, 2010 | 10:04 PM
0MGHI2U's Avatar
NOPE freaking had the hood sensor disconnected and new battery installed and IT STILL WENT OFF ON ITS OWN!!!! WTF!!! OK so i read on some random forum to change the Key Fob Battery.. so i just did lets see if this helps
Old Mar 5, 2010 | 01:29 PM
Um yeah captain obvious?? Whats your point? I'm pretty sure me and the others that are having problems with our alarms would have checked that first.....
