need tire help ??
Old Mar 7, 2010 | 04:35 PM
SN00P's Avatar
CLUB MODERATOR
need tire help ??
best size tires or opinions ... for 19x9.5 rear and 19x8.5 front +35 all the way around ... looking for a flush look and aggressive look ... now i no the +35 in the rear will be perfect flush look for the back now ... the front +35 im looking to get that flush will it be a ok look all the way around or would i need some spacers to achieve that look in the front !! i have tein s-techs but not on yet .. will i need to roll FENDERS or sould i be ok .. im trying to stay away from that if i can ... please help
and was wondering if someone had a picture or something with the same or kinda close setup as this ... i need to no before placing order on tires so i dont make a mistake ??
thanks everyone for the help
Old Mar 7, 2010 | 06:14 PM
SN00P's Avatar
CLUB MODERATOR
anybody ???
Old Mar 7, 2010 | 08:35 PM
str3zz's Avatar
I have 245/35/19 at front and 275/30/19 and it's pretty flush in there
Wheel Size / Offset
Front: 19x8.5 +43mm
Rear: 19x9.5 +43mm
I did have to roll my fender
Old Mar 7, 2010 | 08:36 PM
str3zz's Avatar
Front should be fine mine never touch the fender but rear a must after u drop the car
Old Mar 7, 2010 | 08:51 PM
SN00P's Avatar
CLUB MODERATOR
should be fine without the springs for now ??? so i DO HAVE to roll fender in rear ??? how much does a local shop normally run you ?? i heard that sometime your side fender bend or something if it isnt done right ...
str3zz can you post up a pic of your car so i can get an idea ?? thanks man
Old Mar 7, 2010 | 08:52 PM
SN00P's Avatar
CLUB MODERATOR
so with my +35 offset it should be about the same as what you are running or different ??
Old Mar 7, 2010 | 08:58 PM
str3zz's Avatar
i sent you PM
Old Mar 7, 2010 | 09:01 PM
str3zz's Avatar
Mine is a little wider by +10 from yours and it did hit the fender even with stock springs and shocks
so I rolled the fender and drop the car with 350z shocks and Eibach sportlines springs and it came up flush with the fender.
my suggestion to you is to replace your rear springs which very easy and it should take no more than 1 hour for both sides and see if it hit or not ... you can tell by measuring from the drop point + half/1 inches more after settle and see if it hit the fender. if its not then you are good.
I think if you get 255 or 265 wide it should be fine. front keep it 245 and shouldn't have any problem
Old Mar 7, 2010 | 09:03 PM
str3zz's Avatar
I actually did it my self by using a pole and blow dryer and just roll it slowly
Old Mar 7, 2010 | 09:09 PM
SN00P's Avatar
CLUB MODERATOR
really ?? thats crazzy im just afraid if i do it i will mess something up you no ... but we shall see
Old Mar 7, 2010 | 09:16 PM
str3zz's Avatar
Did you get my pm??
you need at least 2 people to do this. one is holding the heat gun/hair dryer and make sure keep it warm and don't use to much power just let it slide from the tire to the fender by going front back back front and just repeatedly and slowly the fender will roll by it self
the only problem a lot of people complaining by doing them self is the paint got chipped off but if you are carefull and make sure keep it warm all the times it should be fine
Old Mar 7, 2010 | 09:19 PM
SN00P's Avatar
CLUB MODERATOR
yea i got your pm i sent you a message back thanks for the help
Old Mar 7, 2010 | 09:21 PM
SN00P's Avatar
CLUB MODERATOR
do you have a picture of the inside of a fender rolled ??? im just curious of what it looks like after its complete ??
Old Mar 7, 2010 | 09:32 PM
str3zz's Avatar
My tire is completely tuck in in the back and the front is about half a pinkie finger gap
I don't have the picture from inside
Old Mar 7, 2010 | 09:34 PM
SN00P's Avatar
CLUB MODERATOR
your offsets are higher than the ones i got +35 will those tires sizes you recommended with your offset work with my offset the same ??
