need tire size help ASAP
Old Mar 9, 2010 | 11:34 AM
SN00P's Avatar
CLUB MODERATOR
for 19x9.5 and 19x8.5 aggressive look ... best opinions please nothing to EXTREME but i am rolling my fender when i drop my car
please help need to order wheels today
thanks everyone
Old Mar 9, 2010 | 11:55 AM
STCLAIRWEST's Avatar
What are the offsets?
Old Mar 9, 2010 | 11:58 AM
FlyingLumpia's Avatar
offsets, do you want them to be stretched. Do you want a fat or thin side wall?
Old Mar 9, 2010 | 12:05 PM
SN00P's Avatar
CLUB MODERATOR
rear is +35 and the only offset for the front i could find were +45 and i plan on puttin a spacer on the front i want a flush look all the way around ....
i kinda want a thin side wall cause when i lower the car i dont want to do anything extreme beside fender rolling in the rear when its lowered ...
now when you say stretched does that cost more to do when the tires are put on or what
thanks
Old Mar 9, 2010 | 12:32 PM
nghiars's Avatar
STRECTHED would be fitting tires that are undersized for the rim, forcing the tire to stretch. This would allow you to have the lip of your rim poking out beyond the fender while the tire is stretched enough to slant and fit under the fender.
You could run 245/35/19 and 265/35/19... not a stretched look by any means but should be flush.
Old Mar 9, 2010 | 12:38 PM
SN00P's Avatar
CLUB MODERATOR
i thought those same tire sizes and have been calling around here and half the places cant even find them or anything ... im looking for some basic tires nothing very expensive ...
can you post a car close up with a stretched tire .. . can local tire shops do a stretched set up ??
Old Mar 9, 2010 | 12:55 PM
SN00P's Avatar
CLUB MODERATOR
well what if i don't want to roll my fenders and when the car is lowered it will be tucked slightly and just do a stretched tire and make the tire slant in right up close to the fender .. can that be a option ??
nghiars's Avatar
Stethced tires:
https://g35driver.com/forums/picture...ost-em-up.html
Some shops will do it and some won't. Some will say that its not safe to ride like that so they wont do it.
Old Mar 9, 2010 | 12:57 PM
nghiars's Avatar
a streched tire fitting in the wheel well wont look right without your fender rolled. id rather have my fender rolled and have a tire with meat on it instead of stretching it.
Old Mar 9, 2010 | 01:12 PM
SN00P's Avatar
CLUB MODERATOR
so 245/35/19 and 265/35/19 will work .. are there any other size options
vitamin.v
Nov 7, 2019 06:10 PM
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
paolojericho11
Sep 11, 2015 07:08 AM
Jnm07
Aug 6, 2015 03:03 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
