Aluminum pedals
Old Sep 15, 2004 | 01:53 PM
smokeator's Avatar
Aluminum pedals
I Just got my pedal set from everythingg35.com today and read the install DIY (btw was very helpful) Question is that it also came with the e-brake pedal that doesnt fit at all. Does anyone know how this goes on?
Old Sep 15, 2004 | 02:22 PM
Xman's Avatar
Re: Aluminum pedals
I just krazy glued mine over the original. Make sure you let the glue harden well.
2K4 G35x/ etc...
Old Sep 15, 2004 | 02:28 PM
Vegas79's Avatar
Re: Aluminum pedals
I think you have to glue it on. I remember reading this somewhere and they were recommending the use of 3m adhesive. I don't remember where I saw it though. I'll post the link if I find it.
2004.5 G35 Sedan 6MT Garnet Fire/Graphite Leather
Premium / Bose / Sport / Aero / Sunroof / Tint / K&N
Old Sep 15, 2004 | 02:38 PM
cato's Avatar
SouthernComfort Moderator
Re: Aluminum pedals
I took a razor blade and cut the edges of the ebrake pedal
so that it would fit over the original e-brake pedal. Then took
a good epoxy glue and glued it on. This method works very
well. Some people attach with nut and bolt.
03 5AT Sedan, sunroof, splashguards, HKS muffler,
14 wire Grounding kit, Z Duct, Stillen HF/AB
Underbody rear diffusers, Drilled alum pedals,
Stillen sway bars H/H
Old Sep 19, 2004 | 10:02 PM
sickpig's Avatar
Re: Aluminum pedals
I did what Cato did. Pull off the stock rubber pedal. Trim the rubber on the new pedal so it will fit up snug. Glue it on.
Mark
2003 Sedan AT. Ivory Pearl/ Willow
20% tint. Z-tube. Clear Corners w/ PIAA.
Aluminum Pedals
Old Sep 19, 2004 | 10:15 PM
smokeator's Avatar
Re: Aluminum pedals
thanks i went with the glue and it works like a charm. Now to the next mod!!!!!!!!!!!!!!!!!!
Old Feb 11, 2006 | 07:46 PM
skeleton_cru's Avatar
Sedan
I know I'm dredging up old news, but I just used this thread today. I finally got around to installing my Nismo aluminum pedal kit and I couldn't remember how to install the e-brake pedal. Fifteen minutes searching yielded this thread. The epoxy is setting as we speak.
Old Feb 11, 2006 | 11:55 PM
DaveB's Avatar
I bolted mine on.
Old Feb 12, 2006 | 12:27 AM
Sedan
Originally Posted by DaveB
I bolted mine on.
I thought about that, but the epoxy seemed easier. Turns out it was some work to trim the rubber from the back of the new pedal, but well worth the effort.
Old Feb 12, 2006 | 02:57 AM
G35Papa's Avatar
I too went the glue route....about a year or more ago...hasnt budged a bit since then.
I removed the rubber with a utility knife...seemed to be the easiest way for me.
For those still doing these installs....the rubber you remove from the back of the ebrake pedal is only the lip that would normally wrap around the metal base itself. (hope that makes sense). After applying the glue, I used a pair of vise grips and let it sit overnight.
Old Feb 13, 2006 | 01:37 AM
perry05G35's Avatar
I just boiled my aluminum brake cover to get it soft and then fit it over the medal boot it didn't take as long to get it to fit as I thought it would. No glue or drilling necessary work smarter not harder! The gas pedal was a whole nother story took me about 30 minutes to get that one on.
Old Feb 13, 2006 | 02:01 AM
sd_diver's Avatar
Perry,
They are talking about the pedal that goes over the emergency brake. It is basically just the aluminum clutch pedal but does complete the look. The kits the everythingG35 sold had this addl. piece. They recommend using 3M adhiesive (sp??) tape - not included. I used a lot of hot glue after my first attempt (5 min epoxy) failed. 6 weeks and it is still going strong.
sd_diver
Old Feb 13, 2006 | 03:29 AM
perry05G35's Avatar
Originally Posted by sd_diver
Perry,
sd_diver
Good catch I didn't even know there was a piece for the emergency brake guess I will have to go with out since I already got the pedals w/o the emergency brake
Old Feb 13, 2006 | 03:04 PM
cato's Avatar
Yeah, you don't what that fugly black rubber e-brake next to those beauties!
Old Feb 13, 2006 | 03:13 PM
perry05G35's Avatar
Hey stop that it's just not worth spending $74.00 for one piece
alessandro
Oct 8, 2015 09:29 AM
AL8782
Oct 3, 2015 10:26 AM
blnewt
Sep 25, 2015 01:48 PM
Blindside360
Sep 18, 2015 09:00 PM
