Stalling problem on an 5AT!!!
Old Apr 5, 2010 | 01:16 AM
BJD275's Avatar
Hey guys,
I just replaced my dead battery and my car started up fine, then I took it up to the auto-parts place and had them check my alternator and ever since he hooked up the machine to my car-I'll start it and it will stall or come close to it. Here is a video of it (this time it didn't stall but came close, sorry for the poor quality it is off my iPhone; just watch the tach). Any suggestions??
Old Apr 5, 2010 | 01:59 AM
socialconflicts's Avatar
no clue but whatever he did must have messed with something, i would take it back or talk with the dealer >.<
Old Apr 5, 2010 | 02:04 AM
thescreensavers's Avatar
Mr.202?
Try these,skip the ECU reset
<u>Basic ECU Reset</u>
Operations Procedures:
1. Confirm that accelerator pedal is fully released, turn ignition switch “ON” (NOT start) and wait 3 seconds.
2. Repeat the following steps (2a and 2b) procedures quickly five times within 5 seconds.
2a. Fully depress the accelerator pedal (HARD).
2b. Fully release the accelerator pedal.
3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the CEL starts blinking.
4. Fully release the accelerator pedal (while the CEL is still blinking)
5. Wait about 10 seconds.
6. Fully depress the accelerator pedal and keep it for more than 10 seconds.
7. Fully release the accelerator pedal (The CEL light will continue to blink).
8. Turn ignition switch to “OFF” position and now you can start the car. The CEL light should be gone. If the CEL light continues to remain ON, repeat the above steps. Remember, timing is EXTREMELY critical to resetting the ECU. You may even need someone's help to do this correctly.
Note: The following reset procedures are directly from the 2004 G35 Sedan Service Manual.
<u>Accelerator Pedal Released Position Learning</u>
Description:
Accelerator Pedal Released Position Learning is an operation to learn the fully released position of the accelerator pedal by monitoring the accelerator pedal position sensor output signal. It must be performed each time harness connector of accelerator pedal position sensor or ECM is disconnected.
Operation Procedure:
1. Make sure that accelerator pedal is fully released.
2. Turn ignition switch ON and wait at least 2 seconds.
3. Turn ignition switch OFF and wait at least 10 seconds.
4. Turn ignition switch ON and wait at least 2 seconds.
5. Turn ignition switch OFF and wait at least 10 seconds.
<u>Throttle Valve Closed Position Learning</u>
Description:
Throttle Valve Closed Position Learning is an operation to learn the fully closed position of the throttle valve by monitoring the throttle position sensor output signal. It must be performed each time harness connector of electric throttle control actuator or ECM is disconnected.
2. Turn ignition switch ON.
Make sure that throttle valve moves during above 10 seconds by confirming the operating sound.
<u>Idle Air Volume Learning</u>
Description:
Idle Air Volume Learning is an operation to learn the idle air volume that keeps each engine within the specific range. It must be performed each time electric throttle control actuator or ECM is replaced, or if idle speed or ignition timing is out of specification.
Preparation:
Before performing Idle Air Volume Learning, make sure that all of the following conditions are satisfied. Learning will be cancelled if any of the following conditions are missed for even a moment.
- Battery voltage: More than 12.9V (At idle)
- Engine coolant temperature: 70 - 100 Degrees C (158 – 212 Degrees F)
- PNP switch: ON (Park/Neutral Position Safety Switch - AT only, MT fully depress clutch)
- Electric load switch: OFF (Air conditioner, rear window defogger, headlamps. Note: on vehicles equipped with daytime light systems, if the parking brake is applied before the engine is started, the headlamps will not be illuminated.)
- Steering wheel: Neutral (Straight-ahead position)
- Vehicle speed: Stopped
- Transmission: Warmed-up (For A/T models, drive vehicle for 10 minutes.)
1. Perform "Accelerator Pedal Released Position Learning"
2. Perform "Throttle Valve Closed Position Learning"
3. Start engine and warm it up to normal operating temperature.
4. Check that all items listed under the topic PREPARATION (previously mentioned) are in good order.
6. Confirm that accelerator pedal is fully released, turn ignition switch ON and wait 3 seconds.
7. Repeat the following procedure quickly five times within 5 seconds:
7a. Fully depress the accelerator pedal.
7b. Fully release the accelerator pedal.
8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the MIL stops blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the MIL turned ON.
10. Start engine and let it idle.
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure that idle speed and ignition timing are within the specifications:
Idle speed A/T: 650rpm, + or - 50 rpm (in P or N position)
Idle speed M/T: 650rpm, + or - 50 rpm (in N position)
Ignition timing A/T: 15 Degrees BTDC, + or – 5 Degrees BTDC (in P or N position)
Ignition timing M/T: 15 Degrees BTDC, + or – 5 Degrees BTDC (in N position)
13. If idle speed and ignition timing are not within the specification, Idle Air Volume Learning will not be carried out successfully. If idle speed and ignition timing are within the specification and Idle Air Volume Learning cannot be performed successfully, find the cause of the incident by referring to the following Diagnostic Procedure:
1. Check that throttle valve is fully closed.
2. Check PCV valve operation.
3. Check that downstream of throttle valve is free from air leakage.
4. When the above three items check out OK, engine component parts and their installation condition are questionable.
5. If any of the following conditions occur after the engine has started, eliminate the cause of the incident and perform Idle Air Volume Learning all over again:
- Engine stalls.
- Erroneous idle.
Old Apr 5, 2010 | 02:08 AM
C63someday's Avatar
i cant believe the pain in the @$$ it is to reset things on this car, For example on my single turbo 1jz i have to pull a fuse and disconect the battery..
Old Apr 6, 2010 | 12:26 AM
Epidel's Avatar
will disconnecting the battery for 12 hours reset all that stuff? or do you still need to do all these steps
Old Apr 6, 2010 | 05:29 PM
shahzad.shakir's Avatar
I just got the same problem. I haven't tried the reset. Can anyone confirm that the reset works? If not, anyone find a solution?
Thanks,
2004 Infiniti G35 Coupe 5AT - 64k miles - Die Hard Gold Battery.
Old Apr 6, 2010 | 05:48 PM
Epidel's Avatar
i might have a bad gasket =(
Old Apr 7, 2010 | 03:33 AM
G35xChicago's Avatar
From your brief description it sounds like the car just needs to re-learn the correct engine idle level. But in your video, it doesnt even start...
Yes the reset works or you can just disconnect the battery 8-12 hrs
Old Jul 28, 2010 | 08:43 AM
UkraineE39's Avatar
i have the same issue as in the video? Did anyone find the solution.
Old Mar 5, 2012 | 07:17 PM
Sharpdagger's Avatar
05 G35 Sedan stalls at low speed idle
Stall issue,
G35 sedan has stalled 3-times so far at slow speed.
After stall car will not start for a few minutes, cranks normally then starts like there is no issue.
1st time check engine light on, reset - 2nd and 3rd time no check engine light ?
Battery voltage good at idle - 14.2volts.
Need Help !!!
Cleaned T/B, Cleaned MAF sensor, cleaned air filter (not dirty)
CAR RUNS STRONG.
Idle is at 650+/-......
I'm thinking of changing gas filter, car has 100,800mi any help or
suggestions would be great.......
Freeman186
Sep 6, 2023 10:07 AM
mattdg35
Sep 14, 2015 11:28 AM
Gwhut?
Drivetrain
Sep 6, 2015 10:07 AM
TrillO.G.35
Sep 5, 2015 02:06 AM
Jnm07
Sep 5, 2015 01:16 AM
