debading w/ no heat gun?
Old Apr 8, 2010 | 10:48 AM
dsmmyth's Avatar
Originally Posted by FRY TWO
i found it easiest to roll the adhesive off with my fingers..
I did this too, but not before liberally applying some Goo Gone.
Old Apr 8, 2010 | 10:50 AM
JIle342's Avatar
I rolled both before and after applying Goo Gone and it was a lot easier for me without the goo gone making everything all slippery..
also, another tip for the rolling... microfiber towel wrapped around your thumb works wonders..
Old Apr 8, 2010 | 01:13 PM
socialconflicts's Avatar
i will try goo gone and dental floss because i dont have a heat gone nor a hair dryer, thanks for all your input guys.
Old Apr 8, 2010 | 02:37 PM
NFSP G35's Avatar
? = 2B || !2B
also, another tip for the rolling... microfiber towel wrapped around your thumb works wonders...
^Yes it does.
WD-40 works too. I've never needed a heat gun for any of the cars I've done.
Took the door moldings off my trans am with WD-40 and TLC.
Old Apr 8, 2010 | 02:51 PM
thescreensavers's Avatar
Mr.202?
Hairdryer + Fishing Line + Goo Gone + Time = FTW.
This
Old Apr 8, 2010 | 02:59 PM
matdaddy's Avatar
Im thinking about doing the same also... I heard they cant give you a parking ticket if they dont know the make or model of the car is this true!?
Old Apr 8, 2010 | 03:40 PM
35Alive's Avatar
Originally Posted by NFSP G35
^Yes it does.
Yep, WD-40 works good too if you don't have goo gone laying around.
Old Apr 8, 2010 | 05:00 PM
i doubt it, all they need is the vin. it has all the info.
Old Apr 8, 2010 | 05:02 PM
r1forever80's Avatar
Anytime a care comes into shop for paint, i just use a flexible putty knife to take the emblems and moldings off. If careful can be taken off without scratchs. Also i use the 3m eraser to take the adhesive off.
Old Apr 8, 2010 | 07:38 PM
OCG35's Avatar
I still can't believe how many people like goo gone - I hate that ****. It sucks.
3M adhesive remover (its a spray in a red can, hard to find these days)... works better than anything else I've ever used.
Old Apr 8, 2010 | 08:49 PM
Mustang5L5's Avatar
Floss here...wd40 as a lube.
Then i had to buff as my fingernail left tiny scratches in my fragile OB paint. On a sunny day, all you saw.
A year later, and you can't even see it anymore..everything's blended together after a few buffs
Old Apr 9, 2010 | 06:18 PM
Extirpate's Avatar
Started off doing this but wound up using some goo gone and a couple of those wooden chopsticks you get at restaurants (not previously used!!). Worked like a charm.
Old Apr 9, 2010 | 07:04 PM
bound4VIP's Avatar
WD40 isnt a lube WD= Water Displacement 40= 40th formula
not talking crap, just informing
Old Apr 9, 2010 | 07:26 PM
OCG35's Avatar
It's function is used as a lubricant:
"The long term active ingredient is a non-volatile, viscous oil which remains on the surface, providing lubrication"
Quoted from here:
http://en.wikipedia.org/wiki/WD-40
Old Apr 9, 2010 | 07:45 PM
  #30
jbizz's Avatar
yup i heard that goo gone and fishing line works great
