350Z Midpipe Question...
Old Apr 10, 2010 | 11:37 AM
04G35Sedan's Avatar
Hey all, I purchased what was supposed to be a G35 coupe midpipe privately, turns out it was really a 350Z midpipe, which is about 6" short. Is there an already made extension for this that anyone knows of or is it just easier to return it and find a coupe midpipe?
Old Apr 10, 2010 | 01:08 PM
socialconflicts's Avatar
yes there an extention not sure where to buy it, im sure someone else will know.
Old Apr 10, 2010 | 01:31 PM
SN00P's Avatar
CLUB MODERATOR
i found this ....
http://www.mynismo.com/products/?id=4404
IMO for the price you would pay to buy an extension or go to a exhaust shop and them make you an adaptor i would just give it back to the guy and find coupe mid pipe ... you just have to keep your eyes open i got mine locally for $50
Old Apr 10, 2010 | 02:01 PM
also, 350z midpipe gives less sounds, just an fyi
Old Apr 10, 2010 | 02:23 PM
4DGS's Avatar
^ no it doesn't, it's the same piece...
Just weld an extension in, if you can't weld then take it to a muffler shop and say put this on my car and they will weld an extension in.
Bingo bango.
Old Apr 10, 2010 | 06:58 PM
azt108's Avatar
Bingo bango.
noooooooo! do not ever weld! it will crack over time especially if you run on WOT a lot. Welding is weak! 4DGS, is your exhaust welded? I've welded exhaust on two of my cars and both have broken open over time. Try to return it and get the coupe middy. Buy a middy locally or at a reputable online store. They sell it everywhere.
Old Apr 10, 2010 | 08:29 PM
4DGS's Avatar
Sorry dude, but you suck at welding.
The shop I work with welds exhaust all day long, zero problems. The exhaust me and my buddy did on his Dad's camaro has held for 7 years. (winter driven car might I add)
If you know how to weld ( and you're not using MMA) then you'll never have an issue.
AZT, what method of welds did you use?
Old Apr 10, 2010 | 09:36 PM
dofu's Avatar
20 Year Member
I welded an extension on my Z midpipe and that lasted longer than the welds on a set of Kinetix HFCs, and a couple sets of test pipes.
Old Apr 10, 2010 | 09:38 PM
Swivel's Avatar
Moderator
LOL at some of the posts here. I run a welded 350Z middy and it is exactly the same as the coupe mid (except for length) and has held up fine.
Old Apr 10, 2010 | 10:28 PM
04G35Sedan's Avatar
Originally Posted by g35snoop
i found this ....
This was exactly what I was looking for. This will definitely fill the gap perfectly?
Old Apr 10, 2010 | 10:44 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Yes it will, but WHY would you spend $50 on that????
Old Apr 10, 2010 | 10:46 PM
InTgr8r's Avatar
+1
The misinformation is hilarious.
Old Apr 11, 2010 | 02:04 AM
oscar_g-sedan06's Avatar
just try to return it or resale it..i got one off CL coupe mid for $30...then took off resonator replaced with 3''piping..sounds great!!
Old Apr 11, 2010 | 02:40 AM
toymachine2009's Avatar
my welded exhaust has been done for 2 years now. No problems here...
Old Jun 28, 2010 | 11:59 PM
lox1985's Avatar
So does the Nismo extension fit perfectly or is it larger diameter?
