damaged wire harness
Old Apr 30, 2010 | 05:47 AM
lowblocks's Avatar
OK so today my car starts to run like sh** after i hit a real bad pothole(nycstreets) so i took it st8 to my mechanic and he put the car of the lift and to our surprise my hole o2 sensor clip is gone it some how popped off and I'm going threw he** to find the clip to the engine harness is there a part number for this part or some where i can find this clip without having to buy a hole new engine harness some1 please help
Old Apr 30, 2010 | 01:31 PM
SedanManBen's Avatar
I"m sure the dealership could provide you with that information pretty easily and low cost
Old Apr 30, 2010 | 06:00 PM
lowblocks's Avatar
yeah you would think so i call the dealer today and they told me i have to replace the entire engine wire harnesswhich would cost at least a 1000
Old Apr 30, 2010 | 06:01 PM
yogi41's Avatar
Can you just rig it up with a zip tie?
Old Apr 30, 2010 | 06:11 PM
DaveB's Avatar
Pictures please. These are just wires. The all weather clips (I'm assuming that's what you mean by "clips") are simply there for convinence. You could cut and solder the wires.
Old May 2, 2010 | 02:26 PM
Mustang5L5's Avatar
Chop harness off junked car, then all you need is 10 mins with a soldering iron and heatshirnk and it should be good as new
Old May 2, 2010 | 05:38 PM
lowblocks's Avatar
i been to every junk yard in Brooklyn none of them have g35s in them and i don't want to cut my new o2 sensor because that would void the warranty on it and that would be a waste of 200 bucks so I'm looking for any other Nissan and infiniti that take the same o2 if any 1 no any other car besides the z that would take the same o2 please list it oh by the way its the rear right bank 2
Old May 3, 2010 | 01:13 AM
DaveB's Avatar
I still don't understand what exactly is broken on your car. A failed O2 sensor isn't going to cause any sort of significant driveability problem. What harness is this you're talking about? The chassis harness that the 02 sensor plugs into or the harness that comes with the 02 sensor?
Old May 3, 2010 | 01:22 AM
Jeff92se's Avatar
Red Card Crew
It has to be the engine harness side or else he wouldn't be talking about needing an entire harness. If that is the case, (I'll assume it is as the worse case until the OP is able to accurately describe what is broken), then all you have to do is get the wire that has the harness side O2 sensor connector and solder (not crimp, not tie or tape) it in.
If it's just the rear 02 sensor, then just buy another 02 sensor with the plug attached.
Old May 3, 2010 | 11:29 PM
lowblocks's Avatar
yes its the engine harness side and the o2 harness both are jacked up and it does affect drive ability the car has no power above 4k rpm and my car wont start sometimes if any 1 can get me this clip i will give them some money because it don't make sense to buy a new o2 sensor and have to cut it
Old May 4, 2010 | 12:27 AM
DaveB's Avatar
That looks to be your only option here and I don't see what the big deal is. It's just wires. The only warranty you're going to be voiding is the O2 sensor warranty. Big deal, it's a $120-200 part that rarely fails. You're just cutting the harness. It's not like you're modifying the interal 02 sensor components.
Old Jan 24, 2012 | 10:23 PM
DouG35's Avatar
the part number for the sensor is j-48817-189i just replaced mine dont know if you still need it but here
Old Jan 25, 2012 | 05:19 AM
Blue Dream's Avatar
I drove ttrank's car solo
I'm having a hard time understanding what you're talking about but here are a couple of leads. Another good website to poke through for parts is RockAuto. HTH
http://www.slidegood.com/05-infiniti...en-sensor.html
Old Apr 4, 2015 | 02:32 AM
jjpG35x's Avatar
I completely understand what part you're talking about. I'm sorry for bringing up old post. I disconnected my o2 sensors because I was running straight pipes andi didn't cover the wires that you connect the o2s too and now they aren't reading my o2s. I'm also looking for this part. Any help on where you bought it from? I also called the dealership and they said the same thing.
Old Apr 4, 2015 | 06:11 PM
Cux350z's Avatar
I have some spare O2 sensor connectors .4 wire or 5 wire, blue or green?
Marlin84
Apr 1, 2020 12:52 PM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
DRG35R
Jan 31, 2016 07:14 AM
dcsbh1
Oct 1, 2015 03:15 PM
the93owner
Sep 28, 2015 10:37 PM
