Vibration when Braking
Old Apr 30, 2010 | 01:43 PM
jude26's Avatar
I'm experiencing serious vibration when trying to stop from high speeds, 80+ but it does not happen when its normal driving. I'm assuming that the rotors are getting warped. I did a brake job a year ago on the car, but the rotors were resurfaced.
Should I just buy some new rotors or is it because of the high speed. i had to slow down from 120 the other day and thought my wheels were falling off
Old Apr 30, 2010 | 02:04 PM
4drmadness's Avatar
new rotors or need to resurface them again
Old Apr 30, 2010 | 04:02 PM
brandon1978's Avatar
Could also be a bent wheel. You can test for that by swapping the wheels front to rear and see if that changes the vibration during braking. It made a big difference when I replaced my bent wheel. I couldn't tell by looking at it that it was bent, but when it was spinning on the balance machine it was obvious. A bent wheel will be more noticeable up front.
Old Apr 30, 2010 | 04:10 PM
H0TEP's Avatar
Is it the whole car or do you for the most part feel it in the pedal and steering wheel?
Mine kind of does that a little but it's isolated to the pedal and steering wheel, I always thought it was the ABS doing it's job.
Old Apr 30, 2010 | 07:29 PM
dumbg35x's Avatar
"wrap rotor"
Old Apr 30, 2010 | 09:17 PM
Mustang5L5's Avatar
Rotors don't technically warp. It's uneven distribution of pad material on the rotar. For so e reason, the oem 05/06 rotors are prone to it more easily then other cars I drive/own. I know how to avoid it and managed to warp two sets of oem rotors
Either resurface again, or get new rotors. The "warp" comes from when you heat the pads and rotors up in am hard stop and then sit st the light allowing pad material to transfer to the rotors surface.
Old Apr 30, 2010 | 09:33 PM
STCLAIRWEST's Avatar
Ya its most likely warped rotors
Old Apr 30, 2010 | 10:25 PM
thescreensavers's Avatar
Mr.202?
Yea, so would doing the short stops from 60 like new brakes help it go away? Mine is vibrating a tad.
Old Apr 30, 2010 | 10:32 PM
nazc0's Avatar
2006 Vortech supercharged Sedan
mine vibrated when stopping when i put new pads on the car when i bought it but it went away im guessing that i just used brute force to clean out the rotor with my driving style
Old Apr 30, 2010 | 11:15 PM
4D05G35's Avatar
Either resurface again, or get new rotors. .
I would say get new rotors, Im not a fan of twice turned rotors.
Old Apr 30, 2010 | 11:41 PM
Mustang5L5's Avatar
There is a method to try to remove the deposits
http://www.stoptech.com/tech_info/wp...rakedisk.shtml
A good read, but focus on the bottom part
Old Apr 30, 2010 | 11:48 PM
dofu's Avatar
20 Year Member
Or more likely a counter weight fell off. But if the wheel was unbalanced, you should feel the effects regardless of what you are doing.
Old Apr 30, 2010 | 11:50 PM
Texasscout's Avatar
EXACTLY! There is a StopTech "white paper" on their website. I think it's the one listed above.
Old Apr 30, 2010 | 11:55 PM
jude26's Avatar
I don't think its a lost weight or a bent wheel. The car is super smooth at all speeds except between 65-80 where there is a vibration. After 80 it smooths out again.
Old May 1, 2010 | 10:02 AM
Mustang5L5's Avatar
That's different. Warped rotors will vibrate all the way to a stop.
I would look at the wheels
