Vibration when Braking
Old May 1, 2010 | 10:09 AM
Swivel's Avatar
Moderator
Originally Posted by 4D05G35
I would say get new rotors, Im not a fan of twice turned rotors.
Only necessary (but I think likely) if they don't meet minimum thickness spec:
For G35 Sedan:
Front
- Standard thickness : 24.0 mm
- Wear Limit : 22.0 mm
- Max uneven wear : 0.015 mm (measured at 8 positions)
Rear
- Standard thickness : 16.0 mm
- Wear Limit : 14.0 mm
I looked this up because I have a bit of a braking judder myself and intend to inspect/replace the rotors.
Old May 1, 2010 | 10:17 AM
jude26's Avatar
Originally Posted by Mustang5L5
That's different. Warped rotors will vibrate all the way to a stop.
I would look at the wheels
I'm getting both. I have the vibration at speed which i assumed was that i just needed the wheels balanced, they are 20s and i have not balanced them in almost a year.
I'm also getting the strong shaking when I brake from high speed. Does not happen when I'm doing normals speeds, just high speed. AND sometimes the when I brake, the steering wheel tries to turn to the right.
I think i have some serious brake issues
Old May 1, 2010 | 11:33 AM
DaveB's Avatar
Could one or all of the following:
1) Are the wheel centering rings the right size? Do you even have centering rings?
2) If the tires are wider than stock, especially in the front, the tires will be far more more prone to tramlining (ie pulling itself towards ruts, uneven road surfaces, etc). It's more apparant at higher speeds and braking.
3) Out of balance wheel/tire
4) Torn ply in the tire
5) Warped rotor
Seeing that the issue is more prevalent in the 65-80mph range, it sounds to me like a balance or centering ring problem.
Old May 1, 2010 | 11:42 AM
350GT-R's Avatar
I don't think its a lost weight or a bent wheel. The car is super smooth at all speeds except between 65-80 where there is a vibration. After 80 it smooths out again.
that's the case of unbalanced wheel. after 80 it smooths, but, how does it feel when you hit 90-95? shakes more?
Old May 1, 2010 | 06:09 PM
cguerrero523's Avatar
I have the exact same problem when i apply the brakes at a high rate if speed, also i have a slight vibration at around 60 mph. so a warped rotor is what could cause this?
Old May 2, 2010 | 03:53 AM
aaron_boost's Avatar
from high speeds.. maybe ABS kicking in.
bigger wheel/tire combo> the abs is set to stock rims and tires. rpm,mph,ABS,steering,TPMS,braking distance are all affected.
pulling while braking..uneven brake pads/rotors, calipers stuck, brakes need bleeding,wrong brake flluid,suspension(alignment) problem.
other possiblities.
tire balance
worn tires
speeding
Old May 3, 2010 | 09:24 AM
K Dub's Avatar
The fact that it's been a year since you've done any brakework tells me that it's probably the rotors. Ours are very prone to deposit buildup. Sometimes you can STAND on the brakes from about 90 to help it clear up, or try the usual "bedding in" process as you would do if you had new brakes. Other times not so much. I usually just spend the $120 or so and slap a new pair of front rotors on.
Old May 3, 2010 | 01:19 PM
I guess its time for some new rotors then, because only my passenger front wheel vibrates when i apply the brakes slowly.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
Gabe83714
Oct 6, 2015 06:40 AM
alinero718
Sep 27, 2015 09:35 PM
