Battery Problem
Old May 9, 2010 | 08:59 PM
g35kid00's Avatar
Battery Problem
wtf this the third time my battery has died on me since i bought the car back in feb ...i noticed everytime i dont start the car for more than three days the battery dies.
and this week i didnt turn the car on for a day and it died ...what makes it worst is that i took it to sears for a new battery and they said my old battery is good no point in changing
is it true that the radio has something to do with this problem i have a 03 sedan HELP PLEASE
Old May 9, 2010 | 09:46 PM
Texasscout's Avatar
Did Sears do a "Load Check" on it? Did they do a full charge and then hook up a load tester and pull it down to see if it is not calcified? Running a standard battery down below 11 volts more than three or four times is a sure bet to kill it fast.
You need to get someone with an ampmeter VOM Volt Ohm Meter) to check for a drain of more than a few milliamps when the car is shut off. You may have a light on in your trunk that stays on.
Old May 9, 2010 | 10:21 PM
NFSP G35's Avatar
? = 2B || !2B
Is your CD player acting up? If so, that's what's draining your battery.
Find the radio fuse in the under-hood fusebox, pull it, leave your car sitting for 3-4 days and see if it cranks.
Old May 10, 2010 | 02:02 PM
g35kid00's Avatar
cd player doesnt work
Old May 10, 2010 | 02:25 PM
NFSP G35's Avatar
? = 2B || !2B
^There is your problem then.
The CD changer isn't allowing the system to shut down, so it's constantly draining your battery slightly. After about 3 days, it'll have the battery completely tapped out.
Ultimate fix: double-din kit and new head unit.
Temp fix: it is possible to remove the cd changer from the rest of the unit. That's what I did. Now I just have AM/FM and use a cassette adapter for my mp3 player.
Still, that's just to get me by until I can save up enough to finish my in-car PC.
One other temp fix, if you're not brave enough to lobotomize the OEM head unit, is to just find the fuse for the radio and pull it every time you park the car for more than a day.
Only problem is, you have to remember to do it, and if you leave the fuse out, you won't have ac controls either, as they are on the same circuit.
Old May 10, 2010 | 03:30 PM
g35kid00's Avatar
wow ****ing nissan man thats some bull here i am spending all this money on suspension ,rims and now i gotta swap out my radio.......yea i guess its a excuse to get a double din but **** the dam radio is like 500$$$$ its self plus the double din kit ac controls 200$$$ ,plus installation$$$$$$$$$ .....because im not doing none of this **** my self dont wanna risk it
Only thing i did my self was the curbside rim install lol ..but for real im mad
**** man there shouuld b a recall onn this problem and infiniti should fix it for free
Old May 10, 2010 | 03:41 PM
NFSP G35's Avatar
? = 2B || !2B
Yes, it should have been recalled, it's obviously a defect... however, it's not safety related, so a recall is very unlikely. Quite a few of the members on here got thires fixed under factory warranty, but that doesn't do any good for those of us with older sedans with high miles.
Don't blame Nissan though, they didn't build the HU/Changer
Old May 22, 2010 | 05:47 PM
g35kid00's Avatar
SO i had the ***** to tear my car apart and actually remove the cd changer from the rest of the radio wasnt as easy as i thought the little screws on the radio were a bitch most got striped but i got the job done
sorry i didnt take pics but i sold my iphone recently and i have no camera
Anyway im happpy i went ahead and did it now im stress free THANks to NFSP he has been a big help ---SMART guy!!!
o i almost forgot i found my original spare key hidden inside my aftermarket remote starter alarm lol y would somebody put it in there idk
i just saw the tip stickin out the end and was like what the heck is that lol
once again thanks to NFSP lmao
Old May 22, 2010 | 05:54 PM
NFSP G35's Avatar
? = 2B || !2B
No Problem man. Glad you got it done... Yeah I forgot about those tiny screws... but you're right, they were a pain. I almost striped mine too.
Old Jun 19, 2019 | 04:16 PM
Sl33zyvq's Avatar
2004 g35x sedan
Hey man I have an 04 g35x sedan . I’m having serious battery issues. I thought it was old original battery and shitty terminals . That’s not the case . I do have a CD player that from what I know can’t read cds I also have a old parrot 3200 I believe that I’m trying to get rid of cause I believe it’s a parasitic drain . Any help any one where’s the CD fuse ? Any links to take the CD changer or help !
Old Jun 19, 2019 | 05:28 PM
NFSP G35's Avatar
? = 2B || !2B
Holy 9-year necropost batman!
I actually don't remember off the top of my head where the fuse is for the CD player, but like I said, it's the CD, radio, tape, AC controls, everything...
Basically, there's 3 fuse panels where it could be... Under the dash (driver's side footwell, by the ebrake pedal)
By the battery (the one you can see)
By the battery (the one that's hidden and you have to take off the entire battery cover, not just the door)
Freeman186
Sep 6, 2023 10:07 AM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
Ohsixgee35
Sep 16, 2015 04:33 AM
Mhacker
Sep 12, 2015 07:35 PM
Jnm07
Sep 5, 2015 01:16 AM
