Dreaded HVAC/RADIO/AC Problems!
#76
? = 2B || !2B
^That doesn't sound like the circuit diagram problem to me.
A couple of issues you might have:
Compressor clutch itself might be bad. I remember one thread where the guy's compressor clutch actually broke in half (front part came off)
Some vehicles will not engage the compressor if the line pressure is to low to prevent damage to the compressor. IDK if this is the case with the G, but I've seen other cars (mostly GM) that won't engage the compressor at all if the system has bled down too much.
#77
#78
#79
Glad it's not the radio circuit board
#82
#83
Let us know how it goes. It's worth a shot. These shops repairing these boards can't be doing a whole lot on the fix. My 9 y/o Bose/AC unit flaked out for the first time ever two weeks ago. A solid whack to the rightside of the console fixed it. It has to be something pretty obvious on the board.
#85
hi mbridge
Thank you for your advice.
did you buy the radio only, or buy with the face board together?
I am trying to isolate the problem.
Actually, I took it apart last night, and found 2 leads of the ribbon cable burnt to black.
#86
Please do keep us broke-*** G-owners updated
#87
That ribbon cable looks pretty sketchy. When I took mine apart I thought it was the ribbon cable too. Put it back together and it worked for a few weeks and the then shut off again. Then I purchased a new face board, same thing. Finally I purchased the refurb radio and haven't had a problem in a few months now. That leads me to believe that it's the power source and not the contacts.
#88
i cant take this problem no more my radio keeps shutting off and ac turns on...it's really embarrassing i cant have nobody in the car .
i checked the market place ebay and google and i cant find a jdm kit single or double din
i need a 03-04 brown interior kit HELP PEOPLE
ENOUGH IS ENOUGH !!!!!
