WILL THIS FIT ON A 1ST GEN SEDAN X? put in exhaust area but not much feed back
Old Jun 8, 2010 | 07:54 PM
  #31
Bestswat's Avatar
The flanges will bolt up no matter what size but will most likely cause a leak if the difference in diameter is large i dont think it should with .35 but dont quote me on that. What you will notice is rasp though.
If you go from 3 inches to 2.35 inches and then back to 3 inches you will get rasp.
try to keep it in an ascending order like 2.25-2.45-2.75-3. etc.
Clearing the transfer case is a different story so far we only know of 1 y-pipe that clears it which is the HR. Ima be a guinea pig and try one the aftermarket ones i listed above.
Old Jun 8, 2010 | 08:00 PM
  #32
mkvl127's Avatar
awsome!!..let me know how it works out...just by the looks of it..it looks like it should clear it..im not really to worried about rasp..i jus want gains..im doing test pipes aswell nd a hks axle back..keeping the stock middy..i was thinking about doinG a straight middy but i dont want it too loud..with the test pipes new Y and hks axle back it will be loud enough for my taste..mayb a little too loud
Old Jun 8, 2010 | 08:01 PM
  #33
mkvl127's Avatar
awsome!!..let me know how it works out...just by the looks of it..it looks like it should clear it..i feel like any pipe for a car with a stock HR design should fit because by the looks its like the same dimensions jus better flow..im not really to worried about rasp..i jus want gains..im doing test pipes aswell nd a hks axle back..keeping the stock middy..i was thinking about doinG a straight middy but i dont want it too loud..with the test pipes new Y and hks axle back it will be loud enough for my taste..mayb a little too loud
Old Jun 8, 2010 | 09:02 PM
  #34
Dani01c's Avatar
ok so i have an 05 sedan 5 AT, does this 370z/g37 fit, also does it fit if i add the coupe midpipe? im mostly looking for power adders and if those parts give the car a better tone than its even better!
Old Jun 8, 2010 | 09:41 PM
  #35
Swivel's Avatar
Moderator
^^ Both will fit and add some sound and probably a little power.
Old Jun 9, 2010 | 12:16 AM
  #36
Dani01c's Avatar
im trying to find the oem 370z/g37 y pipes but i get some jdm after market ones, the only oems i find are from 350z.. is it the same if i get some aftermarket y pipes for my sedan?
Old Jun 9, 2010 | 10:46 AM
  #37
Swivel's Avatar
Moderator
^^ 350z Y-pipe from an 07/08 (HR) is the preferred OEM unit anyway. Slightly larger piping than the 370/G37 ones.
Old Jun 10, 2010 | 12:45 AM
  #38
Dani01c's Avatar
yeah, thanks for that, i was searching earlier and the g37 y pipe has smaller inlets than G35 ones.. i wish i would have found 350z HR ones, but i only find DE ones which are the same as g35 coupe if im not mistaking
Old Jun 22, 2010 | 04:16 PM
  #39
dsmmyth's Avatar
What about the JIC G37 Y?
Old Jul 8, 2010 | 07:13 PM
  #40
mkvl127's Avatar
^^^ nah that deff wont fit a first gen X..front diff in the way
Old Aug 6, 2010 | 03:48 AM
  #41
Bestswat's Avatar
Someone from G35nyc got the JDM y-pipe to fit.
Old Aug 6, 2010 | 04:15 AM
  #42
SDGenius's Avatar
a lot cheaper option here>>> https://g35driver.com/forums/intake-...pes-found.html
Old Aug 6, 2010 | 07:46 PM
  #43
Bestswat's Avatar
^Nice find, Just ordered it im having exhaust put on this week. I shall be the guinea pig! Will take pics too
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
apintojr
Jul 23, 2015 10:52 AM
justgotg35
Jul 19, 2015 12:33 PM
Jadenkid22
Jul 14, 2015 12:33 AM
