Horrible Starting Issue!
Old Jun 14, 2010 | 01:29 PM
ek-harami's Avatar
My car was outside for abut 3 days, Didnt go anywhere or start it forr that span. On Saturday I was about to go shopping, I tried starting it , would not turn over..then started again and Heard these noises from the motor sounded like 2 wrenches banging against each other...I turned the key off immediatley, then waiting 5 min and tried starting again...Took a "wheeeeeeeeen" then it started back up...then some white smoke came from the engine...So I shut it off...then started back up after 5 min..Started Normally this time!...
I immediately called the Dealer and they were going to send a tow truck to pick it up...I said well let me see if it is drivabale..So i drove it for about 15 min around the block...and off it and started it...it drove normally..weird huh!....I drove it to the Dealership and dropped it off...
I get a call back in the evening, my service guy said it was low on Oil...Im thining whaat!..He checked out everything and he said it looks fine!...
Is there anything else they should be looking at or missing?
I do know the motor eats alot of oil, but enough to make a clacking noise upon startup??..and smoke??..
Old Jun 14, 2010 | 02:53 PM
ek-harami's Avatar
hey guys any insite?
Old Jun 14, 2010 | 03:53 PM
thescreensavers's Avatar
Mr.202?
So wait, your car was not working right, was shooting out white smoke and you drove it any how? If its low on oil it will make noise since there is no lubrication and you probably did some damage do your engine driving with low oil if it was extremely low.
Old Jun 14, 2010 | 04:05 PM
ek-harami's Avatar
The engine drove fine after the start up...The Service Tech mentioned he added 1 qrt of oil...But I checked oil level on flat surface b4 I dropped it off to the dealer. It was right in the middle of the l-f hash mark...And this is at startup and letting it sit for 10 min
Old Jun 15, 2010 | 04:45 PM
ek-harami's Avatar
bump
Old Jun 15, 2010 | 07:08 PM
CG4DR's Avatar
not starting probably caused all the oil to settle which would cause the noise due to a dry start. letting it sit that long depending on age and condition of battery probably a little low on the cca's which is probably the abnormal start. and the white smoke is probably from oil in you motor thats been sitting or gas in the exhaust burning off..
Old Jun 16, 2010 | 01:23 AM
ek-harami's Avatar
Damn ur good!...Thats exactly what the Service Tech said!..Do you think there is any damage..the Tech checked out everything and said the car is fine..
Old Jun 16, 2010 | 07:38 AM
CG4DR's Avatar
Shouldn't be. Just keep an eye on your battery and oil
Old Jun 16, 2010 | 02:03 PM
ek-harami's Avatar
its the original battery so about 6 yrs old...Shall I change it for peace of mind?
Old Jun 16, 2010 | 02:12 PM
CG4DR's Avatar
I Would. don't take the chance of being stranded somewhere
chinee
Jun 10, 2024 07:48 PM
Terry_G35
May 9, 2020 01:39 AM
MyfistYourFace
Aug 8, 2015 11:58 AM
D1dphresh
Aug 7, 2015 06:10 PM
itschuckster
Jul 25, 2015 08:07 AM
