Brakes and SLIP light
Old Jun 14, 2010 | 02:17 PM
g35newbie3's Avatar
Slip and vdc light
So my SLIP light has been going off and on for awhile now. When I took it for an oil change at the Infiniti in Elk Grove, they told me it was because my brake fluid was too low. Well my brake fluid is not low, its actually full.
Then after they changed my oil he told me my pads and rotors needed to be replaced and thats why the SLIP, VDC OFF, and Brake (!) lights are all on. So he told me he would replace my brakes and rotors for the price of an arm and a leg. Well tonight after work I will be changing my front pads because those are the only pieces that need to be changed. My rotors are like brand new front and back and my back pads have a ton of meat left on them.
I just want to know if anyone else is experiencing or had the same problem I am experiencing. If I change the brake pads, will the sensor leave me alone and let my VDC come back on and all the warning lights go away. I hope its just that the pads need changing, but I remember when it got rainy in November I was doing some doughnuts in the rain and slush and the SLIP and VDC lights came on and stayed on.
PLEASE HELP!!!
Last edited by g35newbie3; Jun 14, 2010 at 04:09 PM. Reason: changed title to attract more traffic for help with my brake issue
Old Jun 14, 2010 | 06:26 PM
G35xChicago's Avatar
Search...lots of different info/scenarios on this.
Old Jun 14, 2010 | 07:58 PM
BolognaBlake's Avatar
Have you popped off a battery cable?
Happened to me multiple times in the snow last winter. Just reset the ECU and went on my way.
Old Jun 15, 2010 | 12:30 AM
g35newbie3's Avatar
Welp I guess my hunch was right, my pads were getting a little low and the sensor recognized it I guess. Pads cost me 20 bucks and an hour of time to put on. Piece of cake. SLIP, VDC, and Brake (!) light all went off as soon as the new brakes were on.
Didn't think changing the pads were going to be that fast. Thanks to those with suggestions!
Old Sep 19, 2010 | 07:59 PM
commadanteb's Avatar
what type of pads did you put on for 20 bucks? how do the brakes feel? OEM is 60 bucks
Old Sep 19, 2010 | 08:07 PM
nazc0's Avatar
2006 Vortech supercharged Sedan
im guessing cheap ones from kragen i use them and they feel drippier then oem but after like 5k miles they were reduced to the dust on my wheels
Mry
Mar 3, 2023 01:03 AM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
newg37
Jul 26, 2015 09:32 AM
