05 g35x with dual muffler exhaust?
I'm considering putting dual exhaust on my 05 X, but I looked under my car and noticed a couple things in the way.
First, the rear sway bar. I was wondering if it it possible to exchange a later model OEM sway bar that has room for the second pipe with the stock one.
Second, a black box with fuel lines running out of it. I am not sure what this box does, and am not sure if it would be safe to move it, possibly to the trunk.
The black box is the fuel evap canister. A few Sedans (not Xs IIRC) have done a dual exahaust and relocated it to their trunk.
Check out these threads:
https://g35driver.com/forums/intake-...-complete.html
https://g35driver.com/forums/intake-...l-exhaust.html
https://g35driver.com/forums/g35-sed...-my-sedan.html
Here's my setup:
https://g35driver.com/forums/intake-...stalled-3.html
I was able to keep the evap under the car, as I didn't want to put it in the truck because of fuel fumes. Some people seal it and stuff apparently, but to each their own, I didn't want to take the chance. The thing is though, if you want to fit a muffler in that location, you have to move the evap completely. I just put a muffler in the middle of the car and two pipes back, and there was barely room for the pipe, even after I relocated the evap and moved it vertical instead of horizontal.
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
