spacer question
Old Jun 22, 2010 | 02:50 PM
socialconflicts's Avatar
spacer question
so currently running g35 sedan sport rims 2nd gen, the offset is
Front: +45
rear: +50
if i want the coupe offset i would need 15mm front and 20 mm rear correct? any other tools i may need when getting spacers?
also, would this be my better choice or should i have my tires a little more in?
Old Jun 22, 2010 | 04:41 PM
CandlestickPark's Avatar
ill Sedan
You must also consider the widths of the wheels when doing this calculation.
The 2nd Gen Sedan wheels are:
Front: 18x7.5 +45mm offset
Rear: 18x8.5 +50mm offset
The Coupe 19s are:
Front: 19x8 +30
Rear: 19x8.5+33
Fronts are 21mm more agressive, rears are 17mm more agressive. So to get close to the Coupe specs (without exceeding them) you would need to run 20mm spacers up front and 15mm spacers out back.
Old Jun 22, 2010 | 07:02 PM
The Coupe 19s are:
Front: 19x8 +30
Rear: 19x8.5+33
ahh ok, but based on what i was thinking i was planning on running the coupe 18s style.. thought they were 18x8 +30 all around... unless they are +33 on the rear. but regardless will use the mm spacers u told me.
thanks
Old Jun 23, 2010 | 05:18 AM
im talking about the coupe 18s
the offset to my understanding are
18.8 +30 all around
wouldnt it be 20mm in the rear, but what about the front? i doubt it its 15mm
Old Jun 23, 2010 | 10:24 PM
b-dRizZy's Avatar
uhmm maibii.. i was tiknking off doing 20mm and 15 mm n front
Old Jun 24, 2010 | 01:06 AM
from what i know is u have to take into consideration the front width of the sedan vs coupe
coupe is 18x8 +30 all around so 20mm in the front would fit more flush than 15mm
another member here (kevcog35) is running 20mm all around and this is what he has
this is the specs on his wheels
Sport Model (2005-2006)
Front & Rear: 18x7.5 +45mm offset
Old Jun 24, 2010 | 01:09 AM
kennymo's Avatar
and that looks perfect
Old Jun 24, 2010 | 01:44 AM
Shanomatic's Avatar
I have the same wheels and am running 235/45/18 tires and 10mm spacers on front, 15mm on rear. When I got the new tires on, the guy accidentally put the 15mm spacers up front and it looked really goofy (not including looking at the rear), but 15mm looked like too much for the front.....?
Old Jun 24, 2010 | 01:45 AM
could you post some pics so i can compare?
Old Jun 24, 2010 | 01:48 AM
Shanomatic's Avatar
This is the only pic I have right now. I'll get my camera back from my ex tomorrow and try to upload.
Though I'll try to take some camera phone pics in the meantime...
Old Jun 24, 2010 | 01:49 AM
they seem like they could be poked out a bit more.
Old Jun 24, 2010 | 02:13 AM
Shanomatic's Avatar
Best I can do for now...
Rear
Front
Front
Old Jun 24, 2010 | 02:18 AM
hmm... i may need 15s in the front instead of 20... but for my rears i think 20mm will fit flush...
gcoupe 18s are 18x8 +30 all around
i will test 1 spacer on each side wheel lol!
Old Jun 24, 2010 | 02:19 AM
hurleyguys's Avatar
i dont think it looks bad but i can understand how you would think it looks goofy
Old Jun 24, 2010 | 02:21 AM
his tires are pretty flush, just wondering on mine
jsimonk
Dec 22, 2023 03:49 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
