Headlight, blinker, and reverse light painting... [PICS]
For NiteShades go to:
https://www.amazon.com/dp/B001THRG9Q...F82QM8QH63YXY&
Thanks! Nope, those are factory housings, lenses, and all internal workings.
Appreciate the suggestions guys.
Both pairs of OEM headlights that I own have them... Don't know. :\
Headlights look great, i always go back and forth on whether i want to do them.
Not a huge fan of the doggy door trunk though, but lucky for you i have a solution: I am selling my black (OEM paint) non-doggy trunk. It will come with infiniti emblems and you can use your stock liner/reverse lights. I have it listed in the marketplace but am too lazy to find the link. PM me if interested
this is the next step for me on my 04 coupe....how hard was it for you to separate the lens housing from the inside stuff? I hear it requires putting the whole light in the oven to break the seal...I am very nervous to attempt that.
I love the way the lights look though after you black them out. I tinted my tails, blacked out my grill and side markers and so now the next step is to do the headlights. I have the HID set ups but I think the process is the same.
Nice work
Nice work
It's actually very easy... preheat to 200 degrees, put them in there for 10 minutes, stick the screw driver behind the tabs and pry back slowly. It's really sticky and separates slowly... Make sure you remove the screws holding the lens on before trying to pry it off. Makes it much more difficult if you don't. hahah
headlights look good, i did my turn signals just like that when i had oem headlights. Lose the emblem on the front bumper imo and debadge the I N F I N I T I from the trunk, i removed mine and it doesnt look bad at all underneath like i thought it was gonna look. Also you should paint your reverse lights the same color as your car and make the opening thinner like the 07+ style so you leave just a line untinted small enough not to paint where the bulb goes. Then get 05-06 tail lights
bTanz
Oct 15, 2015 02:31 PM
