My starter going?
Old Jul 2, 2010 | 01:11 AM
Wannabe6MT's Avatar
-MN G Crew-
My starter going?
I don't know what it could be, but it seems like my car is taking longer to turn over and 'catch' almost. It's like it takes a second or two longer to turn over than normal. Normally it just turns off quick and easy. It just seems like it's been taking longer. It almost didn't want to turn over today. It almost caught, then when i let go, it didn't. So i had to turn it again. Tonight is at out in the driveway and turne dit on and off a few times, it taking a second or two longer to catch every time i'd try starting it.
It can't be the battery because its not like its dead (and i just put a new one in 1 month ago..)
No idea what this could be.
Old Jul 2, 2010 | 01:12 AM
Tollboothwilley's Avatar
It could be the starter BUT it could also be the teeth getting worn down on the flywheel (driveplate/flexplate)
Have your changed spark plugs out yet?
Old Jul 2, 2010 | 01:18 AM
Wannabe6MT's Avatar
-MN G Crew-
No, i haven't changed my spark plugs. And flywheel?
Old Jul 2, 2010 | 09:30 AM
ccc123pm's Avatar
X
if you have a remote start that can shorten the life of your starter...
Old Jul 2, 2010 | 09:43 AM
Deezflip's Avatar
I can almost guarantee you that the throttle body needs cleaning
Originally Posted by Deezflip
Throttle body needs cleaning. If i'm not mistaken, you've disconnected the battery at one point. This usually triggers the start-stall issue with a dirty throttle body.
When reconnecting the battery, it's almost like the TPS forgot it's previous settings that compenstated the dirty flap opening. Now, it's acting like it's at a default state where the flap is in more of a shut position, little that it knows, the dirt is blocking that small opening for air to get through at idle. This is my best guess and what I've observed when it happened to me.
When you do clean it, clean it thoroughly making sure that flap still has the spring-back rebound. I've noticed that dirt also gets stuck around where the flap pivots, causing a resistance in the flap movement which is the reason for most of the complaints of rough idling when people here clean them. G/L
https://g35driver.com/forums/g35-cou...now-cause.html
Old Jul 2, 2010 | 10:22 AM
Wannabe6MT's Avatar
-MN G Crew-
So you think its my throttle body? It might be, i had to kinda rev it a little yesterday. Maybe its similar to what happened to the OP in the other thread, just not quite as bad. (i didn't need to rev it to keep it going)
I also have a remote start, but i never use it. In fact, its not even hooked up.
Old Jul 2, 2010 | 10:45 AM
Deezflip's Avatar
^ yeah I think it's the throttle body...did it start happening when you replaced the battery about a month ago? If so, it's definitely the TB. If you've done intake or plenum spacer installs, cleaning it should be relatively simple and cheap.
It blows my mind how this car can't remember its previous throttle position setting, and it can't learn to compensate for the dirty butterfly/flap when reconnecting the battery...but yet, it'll know to adjust accordingly in a slow progression of dirt as long as you don't disconnect the battery.
Old Jul 2, 2010 | 11:34 AM
DaveB's Avatar
If the problem happened shortly after installing the battery, then I'd be looking at the battery. Just because it's new doesn't mean it couldn't be faulty. Bad "new" batteries are quite common hence the reasons for battery warranties.
Cleaning the TB wouldn't be a bad idea either if it's been a while, especially if you formerly had an aftermarket intake.
Old Jul 2, 2010 | 11:38 AM
sdnpaul5at's Avatar
Check the voltage on the battery whithout the car running. It should be at least 12.5 volts.
Old Jul 2, 2010 | 12:57 PM
RADIOGUY21's Avatar
yeah it could be the battery, have it tested. I just changed out my factory original 5 year old battery the other day due to slow/long cranks. Seemed like the battery was not holding a charge for very long, probably had a bad cell as it was old. My car cranks really fast now. I have 62K and while I should clean my TB, I have never cleaned it.
Old Jul 2, 2010 | 01:24 PM
Deezflip's Avatar
actually, didn't realize your description about the turn over part. I don't think it's the TB anymore. If it did start and dies immediately, that would be the TB.
Check that battery terminals are snug tight
Old Jul 2, 2010 | 02:10 PM
Wannabe6MT's Avatar
-MN G Crew-
It's not the battery because the cranks aren't slow and dead feeling. My friend is looking at a G right now with a crap battery and my car does not turn over like that.
My car cranks, cranks the same as it normally does, it just cranks for awhile before catching. Maybe it's a fluke. I didn't seem to notice it this morning as much as i did last night. I'm gonna keep watching it though.
Old Jul 2, 2010 | 03:54 PM
RADIOGUY21's Avatar
maybe its bad gas? What kind do you use?...please dont say Citgo or Costco...
Old Jul 2, 2010 | 05:16 PM
Wannabe6MT's Avatar
-MN G Crew-
I use Shell or BP.
Old Jul 2, 2010 | 05:23 PM
DaveB's Avatar
Check the crank position sensor. It's in close proximity of the crank pulley as it picks up a signal from the pulley. Make sure the sensor or pulley aren't dirty. The sensor itself could be on the way out. It's a fairly common problem on VQs. Easy fix too.
