G35 Sedan with 350z Exhaust
Old Jul 7, 2010 | 11:29 PM
darddoo's Avatar
I have a 2003 G35 Sedan and i just recently purchased the HR-Y pipe and mid-pipe from a 2004 350z, just to make sure from other peoples viewpoints, would that fit in my G sedan ? i wanna put the HR-Y pipe and mid-pipe from the 350z into my G.
thanks.
Old Jul 7, 2010 | 11:31 PM
CandlestickPark's Avatar
ill Sedan
The Y-pipe is a direct bolt on. For the midpipe you'll need to get an exhaust shop to weld on an extension to the midpipe because it will be about 6 inches or so too short. Just an FYI, the Coupe midpipe is a direct bolt on to a Sedan.
Old Jul 7, 2010 | 11:41 PM
darddoo's Avatar
Great, just making sure I wouldn't run into any problems when I take it to the exhaust shop.
one more question ? the stock muffler from the G35 will that be a direct bolt on to the midpipe ? cause I dont have the magnaflow muffler i want to put on it so would i be able to put the stock one on it in the mean time while i get the magnaflow one? or is that gonna be a problem. thanks for the help.
Old Jul 7, 2010 | 11:43 PM
SN00P's Avatar
CLUB MODERATOR
yes your stock exhaust will bolt right up to the midpipe
Old Jul 8, 2010 | 12:19 AM
S 854's Avatar
thanks.
^ HR y pipes are from 2007-2008 350z's (and other Infinitis, ie some AWD's and G37's), so if you did buy from a 2004 350z, you're outta luck.
Go take a look at the big HR y pipe thread in the exhaust section if you want to know the specifics.
Old Jul 8, 2010 | 12:49 AM
Jairen's Avatar
The HR Y-pipe is pictured below. Hopefully you got the right one.
Old Jul 8, 2010 | 01:45 AM
darddoo's Avatar
woow, i had no clue what a bust. soo this that i have would be ? supposedly it was off the 350z
Old Jul 8, 2010 | 01:47 AM
darddoo's Avatar
what do you think it is that i have ?, i posted a picture of it, it's pretty small but hopefully you can still manage ?
Old Jul 8, 2010 | 01:53 AM
SN00P's Avatar
CLUB MODERATOR
it will still work its just a oem y pipe all the same coupe/sedan/350z the HR Y pipes come off a 07+350z or coupe
Old Jul 8, 2010 | 01:55 AM
darddoo's Avatar
would it make a more noticeable exhaust tone if i change the stock sedan one to the 350z y pipe ? is it worth changing ?.
Old Jul 8, 2010 | 01:58 AM
S 854's Avatar
DE y-pipe on left, HR y-pipe on right:
If you use that one you bought, it would make no difference as the OEM y-pipe you have on your sedan is the exact same one.
There are two HR y-pipes FS in the classifieds now, go get one of those.
You really need to read this thread:
https://g35driver.com/forums/intake-...-2003-g35.html
Old Jul 8, 2010 | 01:59 AM
r1forever80's Avatar
I believe its the exact same thing you have already. Just put the midpipe on and leave the y pipe alone
You beat me
Old Jul 8, 2010 | 02:08 AM
darddoo's Avatar
Old Jul 8, 2010 | 02:15 AM
sinnistar's Avatar
what about a g37 coup oem cat back....would any of that work with a 03 sedan???
Old Jul 8, 2010 | 10:43 AM
Swivel's Avatar
Moderator
^^ You can use the Y-pipe but that's about it. Also read the link in Post 11.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Engine - Intake/Fuel CDN
Jul 24, 2015 02:21 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
netcbc
Jul 24, 2015 11:25 AM
