Jacking spot
Old Jul 12, 2010 | 12:11 AM
toymachine2009's Avatar
Jacking spot
Okay I read contradictions can you or can't you Jack on those thin Jack spots on the side of car right where that thin piece of metal is right under the side skirt.. I don't have Jack stands is it okay to lift up right there with a Jack and no not the Jack that comes with the car... Nor do I have a low profile to reach the rear differential..
Just wondering where its safe to Jack the car up without using rear differential..
Some say yes you can and others say it will bend...I just wanna look for a stable place to jack the car up from the side if it's possible.
Old Jul 12, 2010 | 01:19 AM
nazc0's Avatar
2006 Vortech supercharged Sedan
i always jack it up from the side since i cant get a jack in under the diff
Old Jul 12, 2010 | 02:18 AM
Where on the side?
Old Jul 12, 2010 | 02:52 AM
nazc0's Avatar
at the jacking points there is a metal rib thing sticking out with 2 notches in it
Old Jul 12, 2010 | 02:58 AM
okay thanks!
Old Jul 12, 2010 | 10:28 AM
ccc123pm's Avatar
X
I would just put a small block of wood between the jack and the jacking point so you dont scratch the paint...
I usually drive the car up onto some wood blocks so i can the jack under the car to jack from the the subframe
Old Jul 13, 2010 | 05:42 PM
DivZero's Avatar
No, ABSOLUTELY NOT. Is your life worth the $25 you would spend on jackstands?
Hydraulic jacks are not made to hold things up. Even lifts in shops do not rely on hydraulics to suspend the car, they rely on rest points. If any fitting, line, or other part on the jack came loose, the car would fall instantly, killing or maiming you.
Old Jul 13, 2010 | 06:28 PM
I'm not going under car just taking off tire...
Jeff T
Sep 30, 2015 02:00 PM
cmesidewayz
Sep 29, 2015 09:28 PM
Hogbone
Sep 28, 2015 06:44 PM
Adon
Sep 22, 2015 03:56 PM
