What size spacers you think I should throw on this..
Old Jul 14, 2010 | 12:28 AM
toymachine2009's Avatar
My stock 18's what size spacers you think I should throw on this. I dont want a small spacer I want maybe 20mm or 25mm but what do i know... Actually Nothing really about spacers actually how they go on or work or anything.. Will it make the car handle better or is it just an appearance kinda thing..
Also do you have to get different size spacers depending on the wheel you have.. Just wondering for when I get 19" aftermarket wheels if I will need to get diff spacers or its not worth to purchase spacers at this time until I get aftermarket wheels or what.
Old Jul 14, 2010 | 12:31 AM
G35xChicago's Avatar
15 in the front 20 in the rear
Old Jul 14, 2010 | 12:34 AM
98MikeXimaSE's Avatar
anything more than a 10 front and 15 rear would shred the crap out of those squard out tires. you said 20 to 25, be prepared to swap tires outf or much narrower ones
Old Jul 14, 2010 | 12:35 AM
Dealership said I'll have to get longer studs for the lug nuts... Looks like spacers come with studs on them?
Old Jul 14, 2010 | 12:37 AM
Which is why Im asking cause as stated in my first post idk anything bout spacers and sizing?
Old Jul 14, 2010 | 12:39 AM
i personally highly dislike narrow wheels with thick spacers. looks like crap from the behind with a huge gap in the middle. invest in some wide wheels with proper offset.
Old Jul 14, 2010 | 12:56 AM
^true, but doesnt mean he cant make his setup look a bit more flush. Yes, narrower tires will help the cause.
Old Jul 14, 2010 | 01:09 AM
Hard decision.. To get or not to get wheel spacers on my stock wheels.. Anyone else have input?
Old Jul 14, 2010 | 01:21 AM
HenryLee's Avatar
25mm front and rear.
Old Jul 14, 2010 | 01:24 AM
ive seen some 20s floating around in the marketplace, might as well try it if you can ****** em up on the cheap
Old Jul 14, 2010 | 01:41 AM
socialconflicts's Avatar
20mm all around. and i have some for sale too.
this is 20mm all around from a member here
Old Jul 14, 2010 | 01:42 AM
Alright I'll go look for them? 20mm isn't too wide like 98mike said??
Old Jul 14, 2010 | 01:43 AM
How much selling them for?
wouldn't too wide make my tire hit the fender especially speed bumps.
Old Jul 14, 2010 | 01:49 AM
^ 20mm should be fine, u may need your fenders rolled but it all depends how low you are sitting.
Old Jul 14, 2010 | 02:17 AM
geesteezd's Avatar
with that above pic, i'd go 25mm all around
