Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Nov 4, 2010 | 06:45 AM
  #1606
OCG35's Avatar
Originally Posted by NFSP G35
^Good to know... what about in terms of flow? Is one better than the other?
Depends on cell count - lower is higher flow... but realistically you arien't going to tell the diff one from another... and if you did back to back dynos its doubtful you would see enough difference to matter.
Old Nov 4, 2010 | 07:25 AM
  #1607
NjMatteSedan's Avatar
Question. If I get sway bars is it really worth it to upgrade the endlinks? About how long would the oem ones last when aftermarket sways are installed
Old Nov 4, 2010 | 11:16 AM
  #1608
Swivel's Avatar
Moderator
^^ I've had my OEM links running with Stillen sways for about a year and a half (I drive year-round) -- no breakage yet. I think they'll hang in, but I definitely want to get some adjustable ones since my drop puts the OEMs at odd angles so they probably won't work/last as well as they should.
Old Nov 4, 2010 | 11:56 AM
  #1609
Odejc's Avatar
I just installed a FUJITA intake on my 03 sedan. Is there anything else I need to do? Like resetting the ECU...cause it seems like the car is still trying to adjust....
Old Nov 4, 2010 | 12:24 PM
  #1610
3truman's Avatar
I have the same setup, so far no issues.
Old Nov 4, 2010 | 02:30 PM
  #1611
thescreensavers's Avatar
Mr.202?
No harm in resetting the ECU.
Old Nov 4, 2010 | 02:31 PM
  #1612
thanks, i guess i'll do that till they break same as the oem shocks with tein s techs
Old Nov 4, 2010 | 11:32 PM
  #1613
Hammerhead i-Eagle Thrust's Avatar
how well do oem 350z shocks handle sedan drop springs?
Old Nov 4, 2010 | 11:46 PM
  #1614
NFSP G35's Avatar
? = 2B || !2B
^Which sedan springs?
Old Nov 4, 2010 | 11:49 PM
  #1615
idk, something mild that would be like maybe .5 lower then the z springs with a similar spring rate...how low are h-techs?
Old Nov 4, 2010 | 11:52 PM
  #1616
NFSP G35's Avatar
? = 2B || !2B
^I'm trying to remember... off the top of my head, I was thinking h-techs were almost the same drop as z-springs (~1") in which case the Z shocks would be fine.
Old Nov 4, 2010 | 11:55 PM
  #1617
the idea would be to just go slightly lower so the front would look even with the rear
Old Nov 5, 2010 | 12:02 AM
  #1618
hrm htechs are 1.38" front .67" rear
rates are 320/260
s-techs 1.97/1.26 360/270
stock z 314/427(revised)
maybe slapping sedan s-techs on the z shocks wouldnt be the worst idea...
Old Nov 5, 2010 | 12:28 AM
  #1619
3truman's Avatar
be honest!!! would these look good or what? i love them on a mustang but what would they look like on a sedan? aggressive or stupid?
http://cgi.ebay.com/ebaymotors/Anthr...item45f68158a5
Old Nov 5, 2010 | 12:30 AM
  #1620
ehh u might be able to pull it off
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
