Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
  #1966
Old 11-23-2010, 10:49 PM
CandlestickPark's Avatar
ill Sedan
Received 2,687 Likes on 1,448 Posts
Originally Posted by OCG35
it's the brake booster vacuum line (yes it has a one way check valve)... it can't be removed, but it can be relocated (some people tap into the back of the plenum to hide it)... the line runs along firewall to brake booster behind master cylinder...
Yup that's what we did on mine. Tapped the back of the plenum and re-routed to the next to the brake fluid reservoir.
You can see where we tapped it in in this pic, see the blue Earl's fitting sticking out the back of the plenum. Did the same thing to my APS plenum.
  #1967
Old 11-23-2010, 11:11 PM
CG4DR's Avatar
Think you could snap a better pic?
  #1968
Old 11-23-2010, 11:22 PM
Hammerhead i-Eagle Thrust's Avatar
needs moar boostz
  #1969
Old 11-23-2010, 11:30 PM
ill Sedan
Yeah I can take a better one. I'm out of town right now so it won't be till next week at least.
  #1970
Old 11-23-2010, 11:51 PM
thescreensavers's Avatar
Mr.202?
Originally Posted by Hammerhead i-Eagle Thrust
tranny swap ftw
idk if u will save gas passing in 5th, puts more stress on the engine
Dont care much about saving gas, if I am passing someone then my foots on the gas either way.
How exactly does it put more stress on the engine? Low RPM passing vs Higher RPM passing. Engine Load due to gearing?
I rather have most of the load go on the engine then have my tranny shift like nuts. I have good oil in my car so let it do its job. UOA's come out great so my engine is not really stressing.
  #1971
Old 11-24-2010, 12:53 AM
241's Avatar
241
241 is offline
NOOB ALERT!!
how much is the highest WHP anyone got with bolt ons?
test pipes/HFC-intake-headers-exhaust-plenum+tune
  #1972
Old 11-24-2010, 12:54 AM
maybe 265-270 on a dynojet...probably less
  #1973
Old 11-24-2010, 01:03 AM
ill Sedan
OCG35 or butkiss are the two NA Sedans with the most bolt ons. I believe they both dyno'd in the neighborhood of 294-298 on a dynapack (@ Churches in SoCal)
  #1974
Old 11-24-2010, 01:08 AM
which is probably 260-270 on a dynojet
and ocg35 has cams
  #1975
Old 11-24-2010, 02:50 AM
OCG35's Avatar
and ocg35 has cams
I've been on two different dynojets (one of them twice)... based on the gains I've had on the dynapack I'm pretty sure I'd be around 275 on the dynojets I've been on.
All dynos are different though... and with dynojets there are so many variables it's not even worth it to judge a cars performance ability based on the number.
The only thing I ever do is see how my car compares to others on the same dyno that day (it always does well again other VQDE)
  #1976
Old 11-24-2010, 09:19 AM
well yeah, he asked a broad question though
  #1977
Old 11-24-2010, 11:57 AM
CG4DR's Avatar
Why do our cars have such a large loss from crank to wheels?
  #1978
Old 11-24-2010, 12:02 PM
NFSP G35's Avatar
? = 2B || !2B
^All cars do. A lot are around 15-20% MT isn't as bad normally.
  #1979
Old 11-24-2010, 12:10 PM
CG4DR's Avatar
I know alot of cars do it just seems like ours are really high. A rev-up is rated 298 on a 6mt and dynos around 240?? Seems like more than normal
  #1980
Old 11-24-2010, 12:45 PM
NFSP G35's Avatar
? = 2B || !2B
^That would be about 20% loss. (298x0.8=238.4)
That does seem a bit high for a 6MT... but then again it really depends on the dyno and conditions.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
Quick Reply: Random Little Question Thread
