Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Dec 6, 2010 | 09:19 AM
  #2116
JBF's Avatar
JBF
o hai guise
does that software even call out fasteners and nuts/bolts?
Old Dec 6, 2010 | 09:25 AM
  #2117
NFSP G35's Avatar
? = 2B || !2B
^Which nut/bolt do you need to know about?
Old Dec 6, 2010 | 10:21 AM
  #2118
JBF's Avatar
JBF
any and all...
I PM'd screensavers for the link to teh software since i'll need it anyway
Old Dec 6, 2010 | 11:10 AM
  #2119
NFSP G35's Avatar
? = 2B || !2B
^Oh ok. I didn't know if you were just looking for one specific bolt size.
Old Dec 6, 2010 | 04:58 PM
  #2120
socialconflicts's Avatar
so i have been having this problem recently. when my car is cold, and i turn steering wheel to the left and making it go to the max like if i was going to make a U-turn.. the car starts to squeek back.. like a weird squeeky noise... and if i let go of the steering wheel and dont add any force it stops.. anyone know what this could be? the right side is perfect and nothing is wrong with that side.
Old Dec 6, 2010 | 05:03 PM
  #2121
OCG35's Avatar
^^^ could be power steering pump going bad
Old Dec 6, 2010 | 05:04 PM
  #2122
thescreensavers's Avatar
Mr.202?
Your over working the pump. Every car that has Hydraulic power steering makes a odd noise at absolute full lock
But squeaking is not normal, You might want to tighten your belts just a tad.
Old Dec 6, 2010 | 05:08 PM
  #2123
^grant replaced my belts, i may have to ask him to tighten them a tad.
so the loose belts would cause the noise then? i know that loose belts cause noise but i always thought the noise was noticed when the car would first be started.. not from like turning... and why would oit only be one side?
Old Dec 6, 2010 | 05:52 PM
  #2124
silver9's Avatar
Great Thread idea! I have a RWD G with fairly new all-season Goodyear Eagle GTs. I'm wondering if I can fair well in light snow at freezing and maybe below freezing temps. Will it be too much of a problem?
Old Dec 6, 2010 | 05:54 PM
  #2125
silver9's Avatar
BTW I'm on 235/45/18s all around
Old Dec 6, 2010 | 06:24 PM
  #2126
NFSP G35's Avatar
? = 2B || !2B
Loose belts could cause that. The power steering pump will become more "stiff" when it loads up on full-lock. If the belt were just a little loose, it's possible that it may not slip until that extra resistance is added.
It's worth a shot anyway.
You might also try with the car sitting still, turning the wheel a little. Maybe even giving it a fairly abrupt 'jerk' to make the pump load up quickly and see if you get any squeak or chirp from the belt.
Old Dec 6, 2010 | 06:26 PM
  #2127
Stryde's Avatar
Hey, Silver9. I have the same tires (RWD too). They aren't too great. Granted, they're not the worst tire I've used in the snow, but be sure to put some weight in your trunk...maybe a couple sandbags. It will help...and...go slow.
Old Dec 6, 2010 | 06:37 PM
  #2128
my bad forgot to mention. it did this while my car was stopped and was cold. i also noticed that when i was backing out of my parking spot, it did it too.. it was running at very low speeds.
Old Dec 6, 2010 | 06:42 PM
  #2129
NFSP G35's Avatar
? = 2B || !2B
^Any chance you can get a sound clip? It would help.
Old Dec 6, 2010 | 06:52 PM
  #2130
naughty240's Avatar
Id at least get snow tires in the rear. NY don't get more than light snow?
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
