Random Little Question Thread
#4336
Well the horn, just hold I think, lock and unlock at the same time till lights flash, but lights not flash when unlock idk
#4339
#4340
Take the resonator off the midpipe. Done. My Sebring got much louder with it off and no rasp. Only when cold upon startup, but give it a few minutes and it's good to go. Nice and deep (what she said ).
And I didn't forget bout your PM Blain, gonna check tonight and get back to you.
#4342
Was playing a CD, changed discs, then it stopped working. Just says Press Eject. Radio works just fine. From what I'm gathering the OEM head unit it toast, at least the CD portion. Or does anyone know of a fix other than going aftermarket, which will cost me an easy 1k.
#4343
#4344
? = 2B || !2B
Levon, if you're handy with taking stuff apart, you might try dismantling the CD changer. One of the disks may have got jammed.
If for whatever reason you can't get it unjammed, and it runs the battery down, you can actually remove the cd-changer from the headunit and re-install without it (and just use FM or an MP3 player through a tape adaptor)
#4345
#4347
#4348
Hi, my friend is getting the sedan g35, and he wants to get a new intake system. I did this with my car (not g35) and it required a tune to come with it...I was just wondering if we go with this K&N intake system (link is below), will it also require a tune for the greater air flow? I guess my main concern is the maf system not recognizing the new airflow.
Also, if there is a better product out there than this K&N that maybe even has the same performance gain...or for a cheaper price, would you care to share.
http://www.stillen.com/product.asp?i...odel=G35%204DR
Thanks.
Thanks.
#4349
? = 2B || !2B
Thanks.
Thanks.
Seriously though, this is a fantastic thread: https://g35driver.com/forums/intake-...s-results.html
#4350
I can't use a tape adapter though, mine didn't come with a tape player.
Thanks.
Thanks.
