Random Little Question Thread
#4486
possibly.
would have to see the bottom end of it to get a good idea though.
also it might be too wide at the bottom.
what size is it exactly?
Edit:
Or if that one doesn't work out you could always order from this website I bought from before when I had this issue
http://autolumination.com/74.htm
Just make sure to order neo wedge type B 10mm diameter.
I would try the SMT 2
probably brighter than the regular LED they offered as their brightest a year ago
Edit:
#4487
just used seafoam for the first time yesterday(via BB), i drove out all of the white smoke but didnt drive it till today. my throttle response was AMAZING! like i hit the gas and it GOES!!! i love it, granted it had 185xxx miles worth of carbon build up and whatnot but it makes me love my car that much more now
Also would you suggest using seafoam with only 75,000 miles?
#4489
#4490
think you have a jammed motor. something is blocking the forward lean gear. Do you hear it try to move?
Most of the time its just gunked up. If your motor was gone you would not have either movement, if you have backwards then the track/gear is being blocked. pull the seat out and look around. Its more like cleaning then anything
#4491
#4493
What method did you use to put the seafoam in? Can you please walk me through real quick so i get an idea how to do it. I feel my car might need this because on a full tank of gas i get about 250-275 miles. Ive change the spark plugs, changed air filter, oil changed every 3k miles and idk what the problem it. Car runs great just horrible mileage.
Edit: yes i would, recommend it. i have heard every 60k u should. i did mine for the first time @185xxx miles
yes, that is horrbible mileage lol, one thing i did to increase my miles per tank is i reset my ECU, i disconnected my battery overnight(just unplug the negative lead from it). in the morning I reconnected it. now heres the crucial part! you must drive like a grandpa for the next 500ish miles(someone correct me if i'm wrong with this value), by drive like a grandpa i dont mean drive 10 under the speed limit, its about how u accelerate! when the light turns green, dont go like you normally would, SLOWLY press the pedal and dont even press it down as much as you would like to. press it so it CRAWLS up to 2k rpms until its next shift, it is painful/embarrasing and you will **** off people behind you, but it works. now why the he1l do you need to do this? so your ECU can "learn" how you drive, and adjust to your style. now if your going the other route(performance vs mpg) obviously do the opposite, not sayin floor it but more aggressive starts. and remember, this doesn't just apply to "off the line" acceleration, also when your on the fwy and wanna speed up, accelerate to your desired speed slowly. the whole acceleration thing applies to other vehicles too(not the "smart" ECU part), as much as i tell her, my wife is still sooo confused as to how i get better MPG, in my car and in hers, than she does in her 2005 Civic DX(bone stock, power nothing). if you saw her drive you would think shes trying to race you at every light lol but it works for me and i get at least 50-65 more miles per tank. so im up from about 320ish to 370-380ish. but now that its seafoamed i hope to see that number rise even more, and then the spark plugs are next
hope that helps! you, or someone else.
#4494
sorry for the crude mspaint pictures but it works :P and in your case just substitute Low for back and high for forward or w/e. you could have anything in there, dust, soda, food... u never know, just clean off the connectors with a paper towel(or even your finger nail). since i had super glue on mine i took a mini screwdriver for glasses and scratched the top off as if i was trying to remove paint for a good grounding point.
be careful when dismantling your switches tho! mine seemed kinda cheap and idk if i would do it agian lol
#4495
I've recently read that you really don't need to move the evap canister on the bottom of the sedan to open up enough room for a dual exhaust. Apparently you can turn it sideways and extend a hose or two....anyone familiar with this? Crazy their hasn't been a DIY in relation to this mod in the sedan section.
#4496
#4497
#4498
You can either have an exhaust shop do it, or you can buy a small pre-fabbed extension pipe.
