Random Little Question Thread
#4516
#4517
on
^You can clean it out.
The problem is a leaking seal, but it's not just a standardized o-ring, it's a specialized design, and Nissan won't sell you just a seal, they want to sell the entire valve cover, which is expensive.
There is a vendor on the site than can get you a set of seals though.
#4518
The problem is a leaking seal, but it's not just a standardized o-ring, it's a specialized design, and Nissan won't sell you just a seal, they want to sell the entire valve cover gasket, which is expensive.
#4520
you mean the circular grommets? those should be apart of the valve cover gaskets. all the cars i've ever done had them
#4524
#4525
your AC is leaking?
Condensation from using your AC is normal. Its just water that is design to exit the engine bay. in most cases the engineers never design that aspect of the engine because it normally lands on a suspension bushings and tears them apart on certain chassis but the water coming out is normal.
Me personally that water puddle is very normal to me, on all cars i've owned.
ilv2xlr8 (07-28-2011)
#4526
on
#4529
#4530
![Frown](https://g35driver.com/forums/images/smilies/frown.gif)
![Embarrassment](https://g35driver.com/forums/images/smilies/redface.gif)
