Random Little Question Thread
#4655
In most cases to let built up moisture drip out to avoid and corrosion, but on occasion they are the mounting points for the tip.
#4657
#4660
If you're buying springs and shocks new you're almost into the same cost as coils...
Springs and struts are going to run you $600, and the struts are almost identical to the OEM ones. Why not spend another $100-$200 and get fully adjustable coilovers...
#4664
I got my Tokico DSpec-9's for $580 shipped from conceptzperformance I believe. Then I got my Tein 350z Stechs for 180 shipped( don't remember the vendor). I'm very happy with the setup. Low, but not too low so I can clear speed humps and such without too much scraping if I take it slow. +1 to 4DGS's comment about the similar cost to a decent coilover setup.
