Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
  #541
Old 08-31-2010, 07:45 PM
WILLIE BEANS's Avatar
oh rly ?? kewl thanks ....
  #542
Old 08-31-2010, 07:48 PM
ilv2xlr8's Avatar
ATE vs Motul RBF600?
  #543
Old 08-31-2010, 07:55 PM
thescreensavers's Avatar
Mr.202?
Association of Teacher Educators ?
  #544
Old 08-31-2010, 07:58 PM
ilv2xlr8's Avatar
Nope...brake fluid:
Ate super blue or motul? Seem to have similar boiling points and I probably won't track the car. Is one better than the other for street use?
  #545
Old 08-31-2010, 11:47 PM
heph's Avatar
Installing springs this week got me thinking, as I'm considering getting coils next spring if I'm not happy with the drop or if the front struts on the x blow...
1. Is there any way to "plan" your height adjustments with coils or is it all trial and error with repeated jacking up and taking wheels off and on?
2. Any trouble with the shock mounting points on the rear handling the extra load with coils? (since oem springs are separate)
3. Are people leaving empty rear lower spring supports on or taking them off to save a little weight?
  #546
Old 09-01-2010, 12:46 AM
socialconflicts's Avatar
Originally Posted by socialconflicts
im going with a full stillen dual exhaust for my sedan and was wondering if i will be able to pass smog checks? im getting this
http://cgi.ebay.com/ebaymotors/Still...Q5fAccessories
i read somewhere( i think here in driver) that will full exhaust one wont be able to pass the smog checks without putting the Y-pipe back, is this true?
can anyone verify if this info is correct?
  #547
Old 09-01-2010, 12:53 AM
NjMatteSedan's Avatar
Originally Posted by ilv2xlr8
Nope...brake fluid:
  #548
Old 09-01-2010, 11:20 AM
3truman's Avatar
The y-pipe does not control emissions so why would your car not pass smog. I'm guessing that if your exhaust is carb legal you should be ok, even in cali but I'm not sure.
  #549
Old 09-01-2010, 11:27 AM
Mr.202?
^ +1
cats control emissions
  #550
Old 09-01-2010, 11:44 AM
The Stimulation's Avatar
1. Not too sure, maybe someone else can elaborate. But if you know how much it drops the car, you can measure upward to figure out how much of a drop you want. Ex: If it drops the car 4" and you want a 3" drop, measure 1" up from the lowest setting point on the coilover. Other than that, trial and error.
2. You mean with a true coilover setup? If so, I haven't had any at all and been driving with true coilovers for quite some time now and I've even had a few bigger dudes in the backseat (no homos)
3. Leave that spring bucket there. It's VERY light. Only time you take it off is if you're replacing it with a toe arm. If you remove it, there goes your toe.
  #551
Old 09-02-2010, 06:05 PM
NFSP G35's Avatar
? = 2B || !2B
Bump!
RLQT must be on first page at all times (though not sticky, because nobody reads those )
  #552
Old 09-03-2010, 01:38 AM
3truman's Avatar
clearly we need more random questions to keep us entertained!
I am bored so here we go, i like these wheels there a little different but i want something different than black wheels
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
  #553
Old 09-03-2010, 01:45 AM
NFSP G35's Avatar
? = 2B || !2B
^Those look like Subaru wheels.
  #554
Old 09-03-2010, 08:51 AM
Sacch's Avatar
Heyyy guys, I tried to fit the jack, it still didnt work
BTW the other day I was admiring my car, then I realized how boring our lower vents look on the 05-06's. Maybe someone should make us some inserts for those vents kinda like the nismo style. Anythoughts on this? or other options? Please no billet grilles. lol.
  #555
Old 09-03-2010, 11:35 AM
OKStateG35's Avatar
I would like to see other options as well. I'm not a big fan of the honeycomb black plastic.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
Quick Reply: Random Little Question Thread
