Random Little Question Thread
#782
Here is how I figured it out. Find a post with a big picture in the message. Click on the "Quote" button and you will see the message and the picture URL. You will see what I mean about the little commands at the beginning and end of the picture's url address. Hope that helps!
#783
Noob Question: I cant figure out how to attach or upload an image on here. Ya i See the "Insert Image" photo, but have no idea how to get a HTML to put it in that line.
Anyone help me out. And yes I did search for threads but, Im sure Im not doing that correct either. Ha! Thanks for your help
[img]http://www.nfspmotorsports.com/forum/MGalleryItem.php?id=1599;preview[/img]
back to oil and such....
I'm going to do a major service pretty soon since she's past 100k...mishimoto radiator, themostat, hoses etc
I want to do a good engine flush/cleaner(kinda like seafoam) but something more engine specific. I want to put it in the crankcase, run it for 15 min and then drain.
any favorites?
any favorites?
#786
Anybody know of a gasket/washer set? Like for the oil drain plug, transmission drain plug, radiator drain plug etc etc. I guess I could just buy em separately but a package would be easier lol
I know some people don't replace them but the factory service manual urges that you do and I think for $1-2, it would be stupid not to.
#788
Can anyone ID this cracked/leaking hose?
I was installing a rear sway last night when I noticed these cracked and leaking hoses running under the axle to the bottom of each rear wheel. One side is worse than the other, but both are cracked where the tubing flares out to the larger fitting.
Is this a parking brake line or something else?
#790
I just painted mine a short time ago. As recommended by forum members, I used the Duplicolor brush on kit. You do not have to remove them and you can choose from silver, black, red, yellow or blue. I used the regular duplicolor spray to paint my hubs to get rid of that nasty looking rust. It turned out great!
#795
