Random Little Question Thread
Old Sep 23, 2010 | 01:33 AM
  #856
ThePhoenix's Avatar
Originally Posted by socalwdup
What does forged mean?
forged wheel is a very light wheel, yet strong and dense. Enthusiasts for high performance in their cars almost exclusively use forged wheels.
On comparing what alloy wheels are on the market you will find that most are one-piece cast wheels, not forged wheels.
and incase you need more detailed info
What is the difference between a forged wheel and cast wheel in the manufacturing processes?
The term “forged” refers to making an alloy wheel by forcing a raw block of metal into a shape with extreme pressure. Forging is an expensive, multi-stepped process.
The casting process involves putting liquified aluminum into a mold. The wheel is formed as the aluminum cools. This process is achieved in different ways, including gravity casting and low-pressure casting.
Old Sep 23, 2010 | 01:35 AM
  #857
thescreensavers's Avatar
Mr.202?
Sedan Sport 18 rays are Casted
Sport 19s are Forged.
Old Sep 23, 2010 | 06:49 PM
  #858
CG4DR's Avatar
anyone know what bulb is in the lower glove box? i pulled it out and it looks like some sort of fuse light soldered in a socket.
Old Sep 23, 2010 | 07:01 PM
  #859
Mr.202?
my 05 has this
There is a mini bulb behind the frosted plastic thing.
Old Sep 23, 2010 | 07:03 PM
  #860
CG4DR's Avatar
Originally Posted by thescreensavers
my 05 has this
twist off the white case lol the bulb is inside
Old Sep 23, 2010 | 07:33 PM
  #861
naughty240's Avatar
Im sure you could mod an 9004 to fit. haha
Old Sep 23, 2010 | 10:53 PM
  #862
ilv2xlr8's Avatar
Originally Posted by ilv2xlr8
How exactly does the mityvac bleeder work? I have this one:
http://www.harborfreight.com/mityvac...ump-39522.html
So do I put the new fluid in the brake fluid reservoir (in the engine bay) or do I put it in the small reservoir that is attached the hand pump? The instructions in the manual don't make much sense to me.
Yes I just quoted my self. Anyone know how to use that? I plan on doing it this weekend.
Old Sep 23, 2010 | 11:33 PM
  #863
G35Papa's Avatar
^See if this helps
Old Sep 23, 2010 | 11:36 PM
  #864
Mr.202?
Gravity bleeding takes much longer but I hear that's a one man job too right?
Old Sep 23, 2010 | 11:38 PM
  #865
G35Papa's Avatar
I've always done it old school....wife or a buddy pushes on the pedal then holds while I loosen the bleeder
Old Sep 24, 2010 | 12:00 AM
  #866
naughty240's Avatar
pump pump hold. just like sex
Old Sep 24, 2010 | 12:49 AM
  #867
ilv2xlr8's Avatar
Originally Posted by G35papa
Thanks for the vid. The way he describes it, the old fluid goes into the reservoir in the hand pump which is what I thought.
So it's fine for the old fluid to mix with the new fluid in the brake reservoir in the engine bay? I think mine is sitting right at the MIN level.
Old Sep 24, 2010 | 03:32 AM
  #868
banelba's Avatar
Ok got the SKUNK2 Intake Plenum Spacer and was thinking about getting the Kinetix plenum add to it. Is it just a waste of money or will it give me some more power.
Old Sep 24, 2010 | 03:39 AM
  #869
dukehotty's Avatar
Knight Rider had forged wheels.
Old Sep 24, 2010 | 09:42 AM
  #870
NFSP G35's Avatar
? = 2B || !2B
If you're talking about the two parts I think you are, they're not at all compatible.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
