Whining noise from engine /powering-up sound at low speeds
Old Aug 1, 2010 | 12:41 PM
Madhu's Avatar
My 03'G35 Sedan make whining noise/power-up type sound when accelerating at lower speeds ( 20-40 mph). Its not doing it at higher speeds.
I took it to couple of local service centres and they couldn't find anything.
Frustrated when frns ask me about this sound
Old Aug 1, 2010 | 01:02 PM
Mustang5L5's Avatar
Do you have the mechanical fan setup?
If so test your fan clutch.
Old Aug 1, 2010 | 01:39 PM
Madhu's Avatar
Hit my ignorance with a baseball bat, I am not sure about the fan set up.
can you please educate me or point out where I can do it myself
Old Aug 1, 2010 | 01:43 PM
Mustang5L5's Avatar
Pop your hood and look behind the radiator. There is a large fan. It's either electric, or it's connected to the engine.
If it's connected to the engine, grab it and try to spin it ( engine off of course) and see how hard it is to spin. If its hard, the fan clutch is prob toast.
Old Aug 1, 2010 | 01:49 PM
Madhu's Avatar
Thank you , I will check this.
Old Aug 1, 2010 | 03:06 PM
ThePhoenix's Avatar
also any chance of getting the sound on vid so we can hear it maybe?
Old Aug 1, 2010 | 05:34 PM
19kdrill's Avatar
I've also had a similar sound. Sounds like it's right behind the firewall on driver's side. Winding up (similar to a gear drive on chevies or fords) can be heard most at lower rpms, like just taking off. I too, will check the fan.
Old Aug 1, 2010 | 09:15 PM
nazc0's Avatar
2006 Vortech supercharged Sedan
did you install a supercharger?
maybe its the hyperdrive powering up
or since your car is an 03 it might be the fan since the hyperdrive only comes on the 04...
Old Aug 2, 2010 | 03:53 PM
Madhu's Avatar
^ no I didn't
Old Aug 2, 2010 | 04:30 PM
azt108's Avatar
My fan is ridiculously loud, and no the bearing isn't shot, the sound of the airflow is annoying.
Old Aug 2, 2010 | 06:47 PM
Madhu's Avatar
I checked my fan, and its not hard to spin. It looks normal to me. Not sure, what the problem is
Old Aug 2, 2010 | 07:15 PM
nazc0's Avatar
does it happen when you are in neutral just reving or only in drive?
Old Aug 2, 2010 | 09:05 PM
Madhu's Avatar
I didn't try it in neutral, but always on drive
Old Aug 2, 2010 | 10:54 PM
nazc0's Avatar
if it does it in neutral then its engine related but if not then drive train
Old Aug 2, 2010 | 11:03 PM
jimNC's Avatar
Is it a certain RPM range? Does it happen only under load (not in Park)? Does it sound like your muffler is going?
