Who here Drive Manumatic/Tiptronic?
Old Aug 3, 2010 | 03:11 PM
azt108's Avatar
Originally Posted by blazeplacid
I think the problem he is worried about is that some people dont know when to shift
My friend with a RSX shifts at like 6,500 RPM...says he gets the most out of each gear...
So when should we shift?
Old Aug 3, 2010 | 03:12 PM
blazeplacid's Avatar
I have no idea, I rarely use it and when I do I shift around 4kish
but thats me.
im not racing or anything ,just a daily driver to work
Old Aug 3, 2010 | 03:16 PM
azt108's Avatar
but thats me.
I do 6.5-7k, make her scream.
Old Aug 3, 2010 | 03:17 PM
thescreensavers's Avatar
Mr.202?
Uh normally, if your just driving normally under 3k. If you wanted to give it the beans you let it get up to redline or do it at any earlier time in MM thats the point you tell it when to shift.
Old Aug 3, 2010 | 03:21 PM
azt108's Avatar
forgot to mention that the VDC must be off for some fun turns. It takes forever to shift though, I can't stand it.
Old Aug 3, 2010 | 03:24 PM
Mr.202?
I keep my VDC on its fine :P, it shifts ok for a Normal AT, just got to compensate for the computer lag.
Old Aug 3, 2010 | 05:03 PM
NjMatteSedan's Avatar
i should try this when i'm on a date. The dumb broad would be like "omg he drives a stick" probably hahah
Old Aug 3, 2010 | 05:06 PM
Mr.202?
^ lol, I been asked is this car stick? after I have driven, I go its something brand new, manumatic, its better then stick.
Old Aug 3, 2010 | 05:12 PM
it is better than stick with with the right mods :-)
Old Aug 3, 2010 | 05:59 PM
Wannabe6MT's Avatar
-MN G Crew-
I'd rather have a stick...
Old Aug 3, 2010 | 06:00 PM
^ i would of never guessed that
Old Aug 3, 2010 | 06:05 PM
Wannabe6MT's Avatar
-MN G Crew-
Although, i will say, having a 6spd in the garage has calmed my desire to drive a manual every so often. But, it is also reinforcing why i wont one in my next car.
Old Aug 3, 2010 | 08:48 PM
Mustang5L5's Avatar
Nothing replaces the clutch pedal. Manumatic is nothing like a real stick. You still feel disconnected with the slushy torque converter. Yeah it locks up...but its still not like a clutch.
Nothing like slipping the clutch out on a hard launch and then slamming back into 2nd gear, getting the car sideways and then doing the same into third.
Yes, Ferrari and lambo SMG's kick ***, but most passenger car manumatics are not clutch less manual transmissions. Not the same design and the feel is not the same. They use a electronically controlled clutch, we just lock out torque converters and hold the shifts longer.
On and I wouldn't recommend driving around at 6500 rpm and holding it there on any automatic transmission. Heat kills automatics, and revving the he'll out of one is one way to heat them up (as well as brake torquing at a dead stop)
I've often wondered about adding a tranny cooler to the car. I have used a nice plate style with a cooling fan on an old automatic muscle car I built. Really helped keepmtranny temps down. This might be overkill on a daily driver, but would be good for a boosted car that is raced often
Old Aug 4, 2010 | 07:35 AM
geew1z's Avatar
90% the time I am in mm mode too, no issues. I still dont like the 2-3 gear slam, but it doesn't seem to have any effect really..
Old Aug 4, 2010 | 08:35 AM
  #30
itgogitrev's Avatar
If you want to keep it OEM, doesn't the X have a cooler for the tranny or the front diff? I'm pretty sure it wouldn't be too difficult to install one. A fan for it would be nice, but I could see it being a little overkill. If anything, put it in front of the radiator and make the rad fan pull double-doody.
