I have a PROBLEM!!
Old Oct 7, 2004 | 05:44 PM
ChicagoG's Avatar
I have a PROBLEM!!
As I was driving to way the engine service light came on and the car begain to shake alittle. Now I only have 15000 miles on it and my last oil chage was 17000 miles ago. Has this happend to anyone before? Any suggestions?
Thanks
Mike
Old Oct 7, 2004 | 05:52 PM
skeleton_cru's Avatar
Sedan
Re: I have a PROBLEM!!
Before you drive another inch CHECK YOUR OIL. If it has enough oil drive to the dealer and get your car checked. I assume you meant the last oil change was 1,700 miles ago?
Old Oct 7, 2004 | 06:28 PM
ChicagoG's Avatar
ok, tow truck is coming right now to the infiniti dealership, and when I pop the hood and started the car the whole engine was shaking pretty bad. Well I wil keep you informed and whats the out come is.
Mike
Old Oct 7, 2004 | 09:14 PM
Boggie1688's Avatar
Good Luck...hope its not the oil issue...
Old Oct 7, 2004 | 11:53 PM
ChicagoG's Avatar
went to the dealership and pick up a lowner and they said they will get back to me tomarrow
Old Oct 8, 2004 | 10:37 PM
chinee's Avatar
It's tomorrow already... what was the problem?
<font color=red>chinee</font color=red>
03.5 G35s
Old Oct 8, 2004 | 11:29 PM
ChicagoG's Avatar
Called the dealership and they said it wont be ready till monday, and they said they see a problem with cylinder # 6. Also they told me to call saturaday to find out what is exactly wrong with it.
Old Oct 12, 2004 | 04:03 AM
cornholio's Avatar
well?
Old Oct 12, 2004 | 08:27 AM
cato's Avatar
SouthernComfort Moderator
The suspense is killing me! What has happened?
03 5AT Sedan, sunroof, splashguards, HKS muffler,
14 wire Grounding kit, Z Duct, Stillen HF/AB
Underbody rear diffusers, Drilled alum pedals,
Stillen sway bars S/H. Sport Tuned Suspension
Old Oct 12, 2004 | 03:35 PM
ChicagoG's Avatar
There making me keep the loaner for another couple of days, and there going to contact INFINITI about the problems. So I have know idea whats going on but Iam getting pissed!
Old Oct 13, 2004 | 06:48 AM
cato's Avatar
Not good news. I can hear it now: "Sir, do you have a few
minutes to talk......" AGHHHHHH!
Old Oct 13, 2004 | 03:27 PM
ChicagoG's Avatar
I talked to them again today and they said they will be replacing the fuel injector in cylinder number 6, they think it was misfireingand they said thats why the car is shaking. Let you no whats up when they put it in.
Old Oct 15, 2004 | 11:48 PM
ChicagoG's Avatar
It was the fuel injectors, just got the car back. They just replaced them.
Old Oct 23, 2004 | 06:16 AM
Silvershadow's Avatar
I'm glad to hear your problem is fixed. From what I have read, the MIL only has to do with emission problems.
The malfunction indicator lamp will come
on in one of two ways:
Malfunction indicator lamp on steady
An emission control system malfunction has been detected. Check the fuel filler cap. If the fuel filler cap is loose or missing, tighten or install the cap and continue to drive the vehicle. The lamp should turn off after a few driving trips. If the lamp does not turn off after a few driving trips, have the vehicle inspected by an INFINITI dealer. You do not need to have your vehicle towed to the retailer.
Malfunction indicator lamp blinking
An engine misfire has been detected which may damage the emission control system. To reduce or avoid emission
control system damage:
a) Do not drive at speeds above 45 MPH (72 km/h).
b) Avoid hard acceleration or deceleration.
c) Avoid steep uphill grades.
d) If possible, reduce the amount of cargo being hauled or towed.
The malfunction indicator lamp may stop blinking and come on steady. Have the vehicle inspected by an INFINITI dealer. You do not need to have your vehicle towed to the retailer.
Old Jan 25, 2005 | 01:17 AM
G5pot's Avatar
I have similiar problem but a lot worse. When reaching speeds above 60 MPH the whole car shakes so much that I can't focus on the gauges. It looks like a blur till I slow down below 60 MPH. I think it might be my snow tires with some ice stuck in between the threads and frozen there cause it's 5 degrees outside. I drove it for about 20 miles and still shakes, then I thought it might be the engine mounts but the car doesn't shake when I accelerate from 0 to 60 it's only when I go past 60 MPH. I guess I should make an appointment or should I just wait till the weather to get warmer?
