cost/name/part number for lower engine guard
Old Aug 16, 2010 | 11:50 AM
TurTLe*'s Avatar
The lower engine shield for the AWD and most likely the RWD as well is connected to 2 side sheilds as well. Very small each side connects to the main center cover by 2 screws.
Well one of covers ripped thru the hole and now bangs against the main shield, getting annoying to me. I cant exactly locate the part on any of these infiniti OEM online parts to get an idea of what the part can cost. My local dealership is an idoit and just wants me to bring it in, pay $110 for them to look at it and get me quote. Not happening.
Old Aug 16, 2010 | 12:05 PM
DivZero's Avatar
You could call an out of town dealer, like one of those that operate the site.
Old Aug 16, 2010 | 12:09 PM
Bigd2k6's Avatar
call another dealership and have them look up the part #'s so you can find out the retail price online or have them fax you a parts explosion so you can tell them which part(s) you need.
Old Aug 16, 2010 | 07:58 PM
G35xChicago's Avatar
Call Riverside and ask them to send you a parts breakdown/drawing. They will have it.
Old Aug 16, 2010 | 10:07 PM
NFSP G35's Avatar
? = 2B || !2B
^+1
also, are you talking about those little side ones or the big center one?
Old Aug 18, 2010 | 01:08 PM
Infiniti Parts Online's Avatar
Hello,
The G35x uses four shields under the car, the main one goes under the radiator and oil pan area. There's a second smaller one, looks like a bat wing and that goes behind the larger sheild.
Then you have the two side shields.
The part numbers goes as follow:
Main shield: 75892-AL80A
Second shield: 75881-AQ010
Left side sheild: 75894-AL500
Right side sheild: 75895-AL500
In the diagram I have highlighted the shields that in the area.
Hope this helps.
G
Old Aug 18, 2010 | 03:28 PM
TurTLe*'s Avatar
^ I love you !!!
can you also get me a price quote for
these are the ones i need. I need pass side mainly but i rather have both.
Old Aug 18, 2010 | 03:34 PM
You're welcome, the feeling is mutual!! (:
The price as follows:
75894-AL500 : $28.46
75893-AL500 : $28.46 ( 75895-AL500 was a typo, its 75893-AL500 )
let me know if you need them, or you can buzz me at our toll free line 866-733-7347 7A-5P Arizona MST.
G
Old Aug 19, 2010 | 07:17 AM
socalwdup's Avatar
i love you long time
Old Aug 19, 2010 | 11:28 AM
OKStateG35's Avatar
I can't quite make out the part numbers from the diagram, but I'm trying to find replacement bolts and clips all the way around the main shield. Mine are all rusty and I'm missing a few.
Edit: I see the part numbers for the 10 clips, but can't seem to find anything on the bolts.
Old Aug 19, 2010 | 11:36 AM
NFSP G35's Avatar
? = 2B || !2B
^I have some. Bought a ton of them and replaced every bolt/clip. I still have extras... wanna buy?
Old Aug 20, 2010 | 10:59 PM
or just go to your local hardware store and find some that will fit!
Old Aug 20, 2010 | 11:33 PM
NFSP G35's Avatar
? = 2B || !2B
^They're about $2 each
Old Aug 23, 2010 | 05:01 PM
OKStateG35's Avatar
^Tried to find some at Lowes. They had similar clips, but no bolts to fit them. I think Fastenal carries stuff like this, but I've never been there.
Are the bolts really $2/each? I think I found the clips online for $.71/each, but it's hard to tell from the pic. How many do you have and how much would you want for them?
Old Aug 23, 2010 | 05:28 PM
The bolts marked:
74630A
74630AB
74630AA
74630AC
are all the same bolt: part number 01456-00691 and they cost .71 each.
there are 17 bolts to hold the shield all around.
part number: 08913-6365A ( C clip ) , 6 are needed for the front. they are .71 cents each.
part number: 08913-6065A ( C clip ) , 4 are needed for the left and right side. they are .71 cents each
last piece is labeled 75898E is part number 01553-09321 ( push clip ) and is .83 cents each. Our catalog system shows it only needs 1!! So, you will have to look under to actually see how many push clips you need.
Note that the numbers shown in the diagram are "part codes" that Nissan and Infiniti use for the catalog program. it is not the actual part number.
Hope this helps.
G
