wheel inquiry
Old Aug 25, 2010 | 02:44 PM
cally's Avatar
wheel inquiry
I'm looking at buying a set of tires and wheels and was curious if someone could help me with the fitting. I have an 06 Infiniti G35X sedan. The following is the sizing info:
Finish: Gunmetal
size: 18 x 7.0
Bolt Pattern: 5x114.3
Offset: 42mm
Center Bore: 73.2mm
Thanks
Old Aug 25, 2010 | 05:00 PM
OKStateG35's Avatar
No idea on the center bore, but the rest of the specs would fit fine. The stock wheels on the sport model were 18"x7" with a +45 offset. If you wanted them to sit more flush with the fenders you would need at least 10-15mm spacers though.
Old Aug 25, 2010 | 05:05 PM
Blue Dream's Avatar
I drove ttrank's car solo
Originally Posted by OKStateG35
No idea on the center bore, but the rest of the specs would fit fine. The stock wheels on the sport model were 18"x7.5" with a +45 offset. If you wanted them to sit more flush with the fenders you would need at least 10-15mm spacers though.
Fixed.
Old Aug 25, 2010 | 05:12 PM
Get_some35's Avatar
7 is pretty narrow
Old Aug 25, 2010 | 05:18 PM
OKStateG35's Avatar
Fixed.
Ahh, good call.
OP, they will still fit, but I'd get at least 18"x8".
Old Aug 25, 2010 | 06:05 PM
cally's Avatar
thanks for the input, what if i added spacers. would that solve the narrow issues?
Old Aug 25, 2010 | 11:31 PM
NjMatteSedan's Avatar
you'd need some major spacers. 7" is way skinny
Old Aug 25, 2010 | 11:37 PM
GEE35FX's Avatar
Do not get the rims, 7" is too narrow. Get something 8 or 8.5" wide
Old Aug 26, 2010 | 08:49 AM
cally's Avatar
well heres the deal. I can get these at a ridiculous price, and have access to 4, 2 inch CNC Precision Machined 6061 Billet Aluminum spacers. this would put them at 9". But I've read that spacers too big can cause problems with bearings and cause other issues. Is this correct?
Old Aug 26, 2010 | 09:10 AM
OKStateG35's Avatar
No matter how big your spacers are, the wheel is still going to be narrow. Not only will it not look that great, but it will limit your tire selection to a pretty narrow treadwidth.
Like I said though, spacers will help push them out to be more flush with the side of the car. If you're going to get them, I think 15mm or even 20mm would be okay. A 2" spacer is huge.
Old Aug 27, 2010 | 12:55 PM
SLVR JDM's Avatar
Get wider wheels, not huge spacers
Old Aug 28, 2010 | 09:09 AM
cally's Avatar
I hear you guys loud and clear, its too bad I had a good deal going. I'm looking at wheels that are 18X8-8.5 right now. cheers
Mkhlmnn
V36 Interior, Exterior & Lighting
Feb 16, 2016 09:27 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
THMotorsports
Midwestern
Jul 22, 2015 10:27 AM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
