Acceleration and A/T response?
Old Feb 18, 2011 | 03:48 PM
  #31
Intense_Geeez's Avatar
@ Bassman..... Thanks bro.... changing my oil in the A.M. and ill check the tranny fluid as well.....
Old Feb 28, 2011 | 01:28 AM
  #32
jtjohnny102's Avatar
Originally Posted by thescreensavers
Reset the ECU, Unplug the Negative Terminal on your battery and hit the brake 3 times. You will loose your radio presets..ect
Reconnect it, and then Drive around in your car
Pop the car into Manual mode and try giving it some beans While controlling what gear that car is in, do not worry you will not hurt the car there is a rev limiter and it wont down shift until you slow down enough for that gear.
If your tranny is slipping you will hear the engine go much higher all of a sudden like it went into neutral.
And yes I would change out the fluid, I changed mine at 40k
When I first got my car I floored it in D but it shifted early..ect did not feel fast, rested the ECU drove it around giving it some beans and its all good.
How come the procedure for resetting the ecu seems so easy while theres other threads that require a multistep timed procedure to reset the ecu...
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
doakley92
Sep 25, 2015 12:58 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
