HELP- 2006 G35 oil consumption- burn
Old Sep 23, 2010 | 01:42 PM
j.southwind's Avatar
Exclamation HELP- 2006 G35 oil consumption- burn
35,000 miles, purchased pre-owned. Going through over a quart every 1000 miles. If I let the car stand a few days, big puff of blue smoke at startup then clear. You can hear chattering at initial startup then quiets down after 5-10 secs. Ive read up about rev-up motors having problems ( not sure if I have a rev-up, maybe you can tell me ), also read recently about valve cover gaskets that leak internally, can't see anything on outside and nothing dripping on ground. Can anyone advise ? Ive brought it to the dealer and they are doing an "oil consumption" test. I have to bring it back every 1000 miles, a couple of times. I just got this car and am pretty sick about it.
Old Sep 23, 2010 | 01:54 PM
VEEG35.0's Avatar
if thats happening u can prob get a new engine from the dealer thats what happen to mee and i had to put like a quart every few days less then 1000 miles and i had a lot of smoke
and i belive u have a rev up the 05-06 r rev up i think
Old Sep 23, 2010 | 02:03 PM
4DoorGRider's Avatar
RS Motors Tuned
The "rev-up" motor is in the 2005-2006 G35 sedan and 2005-2007 G35 coupe with a 6MT.
Old Sep 23, 2010 | 02:05 PM
VEEG35.0's Avatar
^^ thank you
Old Sep 23, 2010 | 02:06 PM
RS Motors Tuned
j.southwind, here are some threads with the TSB on oil consumption.
https://g35driver.com/forums/tsb-tec...ption-tsb.html
https://g35driver.com/forums/tsb-tec...ed-nissan.html
Old Sep 23, 2010 | 02:21 PM
Ep Drifter's Avatar
Originally Posted by JDinhG35
The "rev-up" motor is in the 2005-2006 G35 sedan with a 6MT.
dont forget about the coupe too 6mt offcourse
Old Sep 23, 2010 | 02:57 PM
RS Motors Tuned
^Fixed.
Old Sep 23, 2010 | 03:18 PM
So I read on from one of the links posted that if you fail the OC test, they will now put in a short block, as apposed a the long block which is spelled out in the TSB. Someone said Nissan put it into effect on 8/1/10. Is this a big deal, any major downside ? Also, Does anyone know mechanically where this oil is going, what the actual problem is ? Is it a valve cover leak ( internal) as some suggest or are the original rev-up motor heads just defective ?
Old Sep 23, 2010 | 05:37 PM
5150DS's Avatar
http://www.ehow.com/facts_5890806_lo...ort-block.html
I have never researched it, but based on the blue smoke on startup I would say it is a problem with the piston rings. However I have an A/T so I haven't really looked into it.
Old Sep 23, 2010 | 09:09 PM
Mustang5L5's Avatar
Short block is a block with crank, pistons and rotating assembly all installed.
Long block is the same, but with the heads bolted on.
The issue is the rings, so a short block will still fix the problem. Instead of new heads, they just reuse yours.
arora_g35
Apr 16, 2026 02:52 PM
nickmcc123
Lights
Oct 7, 2017 12:18 AM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
BlackGee35
Jul 23, 2015 01:36 PM
ResoG35Sedan
Jul 14, 2015 10:30 AM
