Tiptronic issues?
Old Oct 4, 2010 | 05:59 PM
Mustang5L5's Avatar
Originally Posted by socialconflicts
the reason behind the whole 4th gear when shifting into MM is so you can pass the 'car' or w/e you are trying to achieve (correct me if im wrong) which is why if u shift to MM it wont stay in 5th, the car sees it as if you are trying to pass something up.
That's how I would see it.
Is 5th gear ratio an overdrive ratio?
Old Oct 4, 2010 | 06:04 PM
NFSP G35's Avatar
? = 2B || !2B
I'm not sure if that's the idea or not. 4th doesn't offer much of an advantage in passing (55 mph range)
In fact, if you punch it hard at 55 in [D] or [4] or [5] the transmission will select 3rd.
^Yes, 5th is an overdrive.
Old Oct 4, 2010 | 06:28 PM
mkvl127's Avatar
ya my 05 sedan will stay in the gear selected say 5th and if floored stays in that gear where as my friends 03 M45 would down shift automatically,,,i guess the older infinitis all did that ..i personally like the newer stlye better
Old Oct 4, 2010 | 06:55 PM
NFSP G35's Avatar
? = 2B || !2B
Some interesting testing I just did.
Appearently MM isn't just "manual" but also a more performance oriented shift logic as well.
In [D] or MM if you're going 55 and punch it to WOT, it will only downshift to 3rd (as 2nd would be just about to run out anyway)
At 45 or a little under [D] or MM will both put you in 2nd at WOT.
The difference is at 50mph. [D] will grab 3rd, but MM in [5] or [4] will grab 2nd just for a sec and wind it out into 3rd.
I should go clock 50-75 in both auto and MM and see how much of a difference it makes.
I forgot to check, but I think it revs higher before shifting (even if you let it automatically shift) when in MM than it does in full-auto.
Old Oct 4, 2010 | 07:48 PM
Mustang5L5's Avatar
Clutch pedal > *
Old Oct 4, 2010 | 08:45 PM
NFSP G35's Avatar
? = 2B || !2B
^Normally I would agree, but, you forgot something:
if (grade==steep & traffic==TRUE)
Clutch = ;
Old Jan 18, 2018 | 03:58 PM
Junior12345's Avatar
I have an 03 sedan when im on 70 mph and change it to manual mode is shifts down to 4 gear i thought there was something wrong with my car but as i see is normal
Old Jan 19, 2018 | 12:14 PM
jbarnett250's Avatar
I wish the MM shift logic would shift automatically just with more sporty shift points until you actually up/down shift a gear and then shift manually from then on.
Old Jan 19, 2018 | 06:13 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Transgo shift kit, problem solved.
G35Rican
Jul 31, 2024 01:37 AM
yosip1115
Sep 9, 2015 03:30 PM
socaldavid
Sep 5, 2015 04:35 AM
kevintandmd
Sep 3, 2015 06:41 PM
UT G35
Sep 3, 2015 03:58 PM
