Grinding sound when you turn on the car and go...
Old Nov 12, 2010 | 06:31 PM
zenicanin's Avatar
I've noticed my car has a grinding sound, but it's like before it shifts into second gear and it only happens immediately when you turn the car on. It will never do it again even if you're on traffic lights, etc... Any ideas? At first I thought it might be some ignition-related problem, but it sounds like it's near the axle/transmission/lower engine... Also I don't think it grinds at all if you accelerate faster. The slower you accelerate after starting the car the worse the grind is... What do you guys think?
Old Nov 12, 2010 | 06:42 PM
drkay's Avatar
I believe it's the ABS self-check which is totally normal. Has it always been there?
Old Nov 12, 2010 | 06:49 PM
zenicanin's Avatar
It's been there since I bought the car 6 months ago or so. The grind doesn't really sound "nice" though. But it does grind consistently at the same time like I said, turn the car on, drive until it shifts the first time, grind, and then never grinds again till I turn it on again next time.
Edit: I did a search for ABS self-check and it sounds pretty much the same thing that happens to my car as well. That's a relief. Phew!
Old Nov 12, 2010 | 09:12 PM
RADIOGUY21's Avatar
yep ABS self-check.
Old Nov 12, 2010 | 10:17 PM
zenicanin's Avatar
ok cool thanks guys!
Old Nov 13, 2010 | 12:45 AM
Dante's Avatar
yea I get the same grinding noise and my brakes feel a little strange for a second but then it goes away...only happens after I start pulling out of the driveway.
chinee
Jun 10, 2024 07:48 PM
TWASkyliner
Feb 8, 2020 08:00 PM
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
BlackGee35
Jul 21, 2015 07:24 PM
tehmoonrulz
Jul 19, 2015 10:44 PM
