Pictures: How to adjust rear shocks on Sedan
Old Oct 25, 2004 | 10:15 AM
G_Money's Avatar
I finally figured out a way to get to my rear shocks so that I can adjust them as necessary/desired. I have the premium package and the reclining rear seats, so I'm not sure how this method works with the non-premium seats. This should works for the Tokico D-specs and probably for the Koni's as well (although I've never seen them up close to confirm). Any shock with a top mounted adjustment should be accessible this way.
Basic Steps:
1. Move rear seats towards the front (engine) as much as allowed.
2. Remove upholstery connecting seat to rear deck. It is attached by plastic guiders and velcro so just get underneath through the edges and pull out.
3. Remove the black rubber boot covering the shock.
4. Adjust the shock!
Pictures attached.
2003.5 6MT Silver G35 Sedan
Injen CAI, Crawford Plenum, Stillen Exhaust
Hotchkis Sway Bars, GroundingGear<P ID="edit"><FONT class="small"><EM>Edited by G_Money on 10/25/04 07:19 AM.</EM></FONT></P>
Old Oct 25, 2004 | 10:16 AM
G_Money's Avatar
Re: Pictures: How to adjust rear shocks on Sedan
Next Picture
Old Oct 25, 2004 | 10:17 AM
G_Money's Avatar
Picture #1 - Original
G_Money's Avatar
The rubber boot covering the top of the shock. It just lays there (it's not secured by anything).
Hotchkis Sway Bars, GroundingGear<P ID="edit"><FONT class="small"><EM>Edited by G_Money on 10/25/04 07:20 AM.</EM></FONT></P>
Old Oct 25, 2004 | 10:18 AM
G_Money's Avatar
With the top of the shock exposed.
Old Oct 25, 2004 | 02:20 PM
IQ9's Avatar
IQ9
Nice pics and info. I was thinking about getting the D Specs.
03.5 Sedan/B.Sil/Prem/Wntr/Aero/Tint/Rims/Hotchkis Sways--WHERE ARE OUR PARTS!
69 Chevelle Hard Top BB/4.11's/Posi
Old Oct 25, 2004 | 03:37 PM
BobbyD's Avatar
Interesting, I didn't know the shocks were adjustable. What setting did you change the shocks to and how is the ride? I would assume the fronts are adjustable as well, ideally you want a balanced set up.
2003 G35 Sedan 6MT
14.13 @ 99.55 (stock)
Old Oct 25, 2004 | 03:41 PM
G_Money's Avatar
I have the shocks set to 4 turns from full hard on the front and back. There are 7.5 turns available, so I'm about half-way in terms of stiffness.
The ride is slightly more firm than the stock sports suspension, but nothing where I can't (or my family) can't tolerate it. The performance is MUCH better so the trade-off on ride smoothness is well worth it IMO.
2003 6MT G35 Sedan, Brilliant Silver
Tokico D-Specs, G35 Coupe Springs, Hotchkis Sway Bars
Old Oct 25, 2004 | 06:12 PM
headpaneer's Avatar
Is it possible for you to have a “stock” sedan ride with the G35 coupe springs by dialing in the Tokico’s?
*'03.5 MT6 Sedan, Premium, CB*
Z-tube, Pop-Charger, Coupe Mid-Pipe, Autovation pedals
*'00 Saleen S281-SC*
Mucho mods. See it here!
Old Oct 25, 2004 | 07:09 PM
G_Money's Avatar
Per GSedan35, Tokico said that the adjustability range includes stock (i.e. stock is somewhere between 0 and 7.5 turns). However, I do have the 350z specific shocks and I haven't been inclined to reduce damper by THAT much. I'm pretty sure that at 7.5 turns, I'd get a "cadillac" type ride.
Actually, I just discovered the way to adjust them so I haven't even played around with different settings.
rezendvous420
May 31, 2020 01:26 PM
mjfenix
Aug 17, 2017 05:49 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
netcbc
Jul 24, 2015 11:25 AM
