G35 problem -_- Help!
Old Dec 30, 2010 | 12:14 AM
neejee's Avatar
so I have a 2004 infiniti G35 sedan with 54,000 miles.
The Vdc OFF service engine soon and slip light are on at the same time.(which bothers me considering its my daily)
and when i first start car and drive and steer to the right it feels lights its grinding against something, but it goes away after a little and performs as should but the lights are a bother.
it also hasnt had a oil change in a while. because i got it from a auction.
any helpful tips would help.
Old Dec 30, 2010 | 12:51 AM
gtivr698's Avatar
First you should flush and replace all your fluids since it is from an auction you dont know who owned it, how long have you had it for? was it in a wreck?
Old Dec 30, 2010 | 10:30 AM
Mustang5L5's Avatar
There is not really much we can do on the Internet.
Go have the cel read at auto zone or buy a scanner, pull the wheels off and start looking for sources of the grinding.Could possibly be wheel bearings, or something in the brakes like a seizing caliper
Old Dec 30, 2010 | 12:11 PM
feebabii's Avatar
This just happened to me and i was panicing. I called the dealer and they said it was my brakes. Got my brakes and rotors done and it fixed the problem. Hope this helps
Old Jan 1, 2011 | 11:54 AM
atmel101's Avatar
Get the codes read, And let us know what it ends up being
Old Jan 1, 2011 | 11:55 PM
kyemaul's Avatar
I have the exact same problem my code was my power steering angle sensor. Which dealer says it 690 dollars I don't know if its the same for yu
Old Jan 2, 2011 | 05:57 AM
atmel101's Avatar
690 wtf
Old Jan 2, 2011 | 11:22 AM
kyemaul's Avatar
That's exactly what I said. The sensor cost $690 that is not the labor to change that sensor.
Old Jan 3, 2011 | 04:10 AM
neejee's Avatar
omg i am so thanful to be alive.... i hust hit this corner at like 50 and i forgot my vdc was not working and my car spun out and did a 360 omg.... thankgod it was a empty area and no damage but still a very scary situation..... now i really wanna get this fixed....
and i go the coded p0101 which is MAF but i dont think that has anything to do with it so ima get the brakes checked out...
Old Jan 3, 2011 | 04:18 AM
TIAN's Avatar
Hold The Line
Glad to hear you're ok. Might wanna take those corners a little slower...
Old Jan 3, 2011 | 05:15 AM
thescreensavers's Avatar
Mr.202?
You should never relie on a system to save your ***. Its there to save your *** when you screw up
Old Jan 3, 2011 | 06:48 AM
Mustang5L5's Avatar
+1
Any other lights on with the vdc? Are the brake and and slip light on?
Old Jan 3, 2011 | 03:14 PM
neejee's Avatar
i took care of the service engine soon light..... but when i started my car there is no lights but as soon as i turn the steering wheel both lights apear.. im thinking it just needs an alignment?
Old Jan 3, 2011 | 03:18 PM
neejee's Avatar
vdc and slip that is.
Old Jan 3, 2011 | 04:42 PM
Mustang5L5's Avatar
Alignments don't cause warning lights to come on.
Are those the only two lights that are on? No brake or abs light?
Check your brake fluid and make sure the fluid level is not low.
