Oil leak
Discussion about the 1st Generation V35 G35 Sedan
Oil leak
Feb 10, 2011 | 06:46 PM
Jeff92se
Red Card Crew
24
May 2005
ɐʍ 'ǝlʇʇɐǝs
Jack up car, look for leak. In the end, that's what you're going to have to do.
Jeff92se
Find all posts by Jeff92se
Feb 11, 2011 | 02:49 PM
obsdnoblivion
Jul 2007
ATL
Is it bad to spray degreaser around the vicinity of the leak? I need to get it clean enough for me to be able to see leaks clearly.
obsdnoblivion
Find all posts by obsdnoblivion
Feb 11, 2011 | 02:57 PM
04nismoG
Jul 2010
I used brake cleaner it will get rid of all the oil with out having to wipe it off and it dries in seconds.
04nismoG
Find all posts by 04nismoG
DIY: Remove Gas Pump to Clean Sending Unit & Clear P0463 Code
RemmyZero
V36 DIY
11:13 AM
G35 non-rev up oil consumption
mbe32
11:09 PM
What are the symptoms of BHG?
BradMD_96
09:31 AM
Please help over heating issues
hrdwirk1
06:34 PM
Engine trouble
vamarris
12:56 PM
Tags
03
2003
2005
35
common
cooler
filter
g35
leak
leaking
leaks
oil
ring
sedan
subaru
Back to Subforum
View Next Unread
Selling Coupe to get Sedan?
5 : Excellent
4 : Good
3 : Average
2 : Bad
1 : Terrible
11:10 PM
