UPDATE FD 3.54 ....Awesome!!!!..
Old May 11, 2011 | 11:22 PM
  #61
g35man04's Avatar
CLUB MODERATOR
quick question my 04 G35 coupe 5AT...Gearing I have is 3.3?? I have been wanting to change my gears into 3.7....if I am 5AT would there be modification needed for the G37 pumpkin?
Old May 12, 2011 | 12:27 AM
  #62
herrschaft's Avatar
Yes, you currently have a 3.3. If you get a pumpkin from a manual G37, you will not have to modify it. If it is from an automatic then you will have to follow the DIY below.
https://g35driver.com/forums/drivetr...tial-swap.html
Old May 12, 2011 | 09:46 AM
  #63
DaveB's Avatar
Originally Posted by Stingray90
Dont you mean, you lower the maximum speed of each gear..? I can't imagine anyone losing acceleration in Any gear by going to shorter gearing. Acceleration should improve in every gear. Atleast that's how it is R/C. Should be no different here.
You can definitely overgear a car to the point that it's slower. Basically too much gear causes the motor to go thru the powerband way too quickly. This is also partly the reason for why adding a deeper gear causes a slight reduction in topend acceleration. What ends up happening, like you said, is maximum speed in each gear is reduced. In the taller gears, this can be problematic because they're simply too tall, even with the deeper rear gear set. It also forces an extra shift in the 1/4 mile which isn't exactly ideal. With the 3.3 gear set, 3rd is good to around 101mph. With the 3.54 gear set, it's good to about 94mph. Since these 5AT easily get 94mph in the 1/4 mile (mine does nearly 100mph), that means a shift into a much 4th and acceleration does tail off a bit. In a highway roll from 60mph, the 3.3 car would probably pull the 3.54 geared car to 105mph. However, from a stop to 105mph, the 3.54 car might have a slight advantage because it would likely be quicker to 50mph. It's hard to explain without showing a bunch of math with calculations for torque multiplication, gear ratios, and wtq/whp. In the end, one must be careful when choosing gear ratios. There's a fine line between too little and too much.
Old May 12, 2011 | 11:27 AM
  #64
kyemaul's Avatar
I believe g37s MT VLSD (3.69) is the highest you should go on a na G or Z. If You are FI then you could definently go higher than that. The 3.54 will def pull off on a 3.3 ratio car.
P.s. dave not to get off topic but how was the update on the sprint booster kit? did you have to change the pedal or what, im looking into a Blitz throttle controler.
Old May 12, 2011 | 11:32 AM
  #65
NFSP G35's Avatar
? = 2B || !2B
^Actually, if you're boosted enough, going deeper isn't always better. Ask Tim Trank, he had too many traction issues.
Old May 12, 2011 | 11:56 AM
  #66
kyemaul's Avatar
I can see how that could be a problem!
Old May 13, 2011 | 05:48 PM
  #67
Stingray90's Avatar
Sorry Dave I'm just not seeing it... (don't get offended, I love constructive conversation).
Yes I certainly agree you can overgear a car, just like you can undergear one. But all things being equal (weight, torque, temp, driver skill, traction, etc..)on a G35, concerning the factory gear ratios available (3.3-3.9) for our cars, the shorter geared car will accelerate faster than one with taller gears. Both from a stop and on a roll. For sake of argument let's say up to 120mph.
Most people who have done the swap seem to acknowledge this. And this holds true on paper as well.
Consistent real life experience is always best for those that care to chime in.
Old May 14, 2011 | 12:00 AM
  #68
DaveB's Avatar
Agree to disagree
I've got a set of 23.5" tall drag radials which give my car an effective gear ratio of around a 3.55 (car had the 3.34 gear set at the time). On same day at the strip, I did four runs with the 26.3" tall OEM 17s and 3 runs with the DRs, which were also 15lbs lighter each than the 17s. The car did consistent higher 14.4s and lower 14.5s@97-98mph with low 2.2 60 foots with the 17s. With the DRs, the car did consistent lower 14.5s at higher 96mph with mid 2.1 60 foots. It never could break into the 14.4s. The car was quicker off the line, in the 1/8 mile, just the same as the 17s at the 1000' mark, but the killer was the forced shift to 4th about 150 feet short of the finish. It crippled both ET and MPH.
Years ago, my friend had a 90 LX 5.0 nothback 5MT. It was basically stock except for a catback, pullies, and hacked airbox. It came stock with 3.27s. It did 14.0s@98mph with the stock gears. He then added 3.73s. The car totally woke up and felt awesome in 1st, 2nd, and 3rd. After that, acceleration tailed off. With the 3.73s it did 14.2s@97. 60 foots were better, it was quicker in the 1/8th, but since he had to run through a lot of 4th, the car slowed down. The 3.73s were just too much gear for that 5.0 that peaked at around 5000rpms. No problem though, he added a heavier breathing cam, intake manifold, valvetrain stuff which extended power to around 6500rpms and it was doing mid 13s. With extra breathing allowed the motor to fully use the deeper gears.
The only reason I went with the 3.54s in my G was because I wanted snappier daily driving, more gearing would help in the auto-x (sub 65mph racing), and I wanted the LSD (huge help in the auto-x). I haven't been to the strip in 2 years. I may try it again with my DRs which would effective gear the car to a 3.75.
Some cars come from the factory woefully undergeared. The 98-00 Cobras are prime examples. They come with 3.27s, but the motor makes good power in the mid to upper rpms and revs out 7000rpms. The long gear don't allow the motor to get into the meat of it's powerband quickly nor fully exploit the powerband. Adding a 4.X series gear will easily shed .3 seconds and add 1-2mph in the 1/4 mile. The G and Z aren't those cars, at least with stock cammed VQs. Nissan did a pretty good job gearing these cars for strong acceleration while trying to maintain some MPG sanity. There aren't many other V6 sport luxury sedan/coupes out there that perform as with just 260-280hp. Since these cars are already decently geared stock, they don't make significant gains when adding deeper gears. They definitely feel quicker since there's more torque multiplication therefore seat of the pants acceleration 'feels' more impressive. Put that feel under the clock and you'll see that the two don't necessarily agree. My friend's 5.0 felt downright brutal in every gear. It felt far quicker than 14.2s. All that torque multiplication mislead the mind.
Old May 15, 2011 | 01:11 AM
  #69
4D05G35's Avatar
Agree to disagree
Good post and info.
Old May 15, 2011 | 01:54 PM
  #70
Stingray90's Avatar
Good feedback Dave,
That's why I like comparing real world data... I'm tryin' to fiqure out what final drive I have in the car now.
4D, have you done the swap?
Old May 15, 2011 | 01:58 PM
  #71
herrschaft's Avatar
http://infinitihelp.com/models/2005/...ifications.htm
Old May 15, 2011 | 02:14 PM
  #72
Stingray90's Avatar
Herrschaft, I already know about that, but thanks.. I meant, I am the second owner and it seems I may already have shorter gears in my car.
I'm thinkin' of pickin up a second rear for trial purposes and see what I like better on the VQ.
Old May 15, 2011 | 02:26 PM
  #73
herrschaft's Avatar
^If your precise, you can tell by spinning the flange. If I remember correctly, 3.3/3.5/3.7...etc is how many times the half-shafts turn for one full rotation of the flange/driveshaft.
Old May 15, 2011 | 03:31 PM
  #74
4D05G35's Avatar
Good feedback Dave,
Yes, just did it last night. Went from an open 3.3 to the VLSD 3.54 and I am very happy with the results. Well worth the $300 spent.
Old May 15, 2011 | 03:38 PM
  #75
Stingray90's Avatar
Nice.. After you give it a few let us know how you like the low & top end compared to the 3.3.
