Need Help Full Wire Tuck!!!
Old Jan 5, 2011 | 05:25 PM
kyemaul's Avatar
Hey guys, I have researched this thing for a while now. Im trying to do a full wire/engine wire tuck. Since I am fixing my valve cover / spark plug oil Leak. I think its probably best to do it now. I am painting the valve cover garnet fire to match my car, but with out the wire tuck it wont be seen as much as I would like. For example when i say full engine wire tuck I am thinking something like candlestickparks(marcus) wire tuck!!! All and any help will be greatly appreciated!!!!!!
Old Jan 5, 2011 | 05:27 PM
Swivel's Avatar
Moderator
I think kennymo started a wire tuck thread, didn't he? Some info there, though IIRC no DIY for a full tuck.
Old Jan 5, 2011 | 05:38 PM
CandlestickPark's Avatar
ill Sedan
Here are a couple of threads that should help you out:
Main harness tuck - https://g35driver.com/forums/engine-...wire-tuck.html
Accessory harnesses tuck - https://g35driver.com/forums/g35-sed...wire-tuck.html
Old Jan 5, 2011 | 05:44 PM
bluedevils95's Avatar
WOW! That should be a fun project for you. Good luck!!!
Old Jan 5, 2011 | 06:09 PM
kyemaul's Avatar
thanks guys...Sorry if i started a kind of double thread!!!!
Old Jan 5, 2011 | 06:14 PM
856_reilly's Avatar
Wire tuck looks so nasty!!!!! I'm going to be doing it soon as i get my motor back in.. I see candlestickpark eng. bay and it sold me... just gonna have to take your time bro!!! post some pics if you can while you doing it. Also pics after.. Good luck!!!
Old Jan 5, 2011 | 06:18 PM
ill Sedan
Thanks man. Yup, that is a huge part of doing a wire tuck. Don't rush things. The accessory harnesses are straightforward, but the main harness can take a while, be patient because you want to be sure and put everything back together properly otherwise you could cause some issues with your car.
Old Jan 5, 2011 | 07:35 PM
You can always do what i do and just do one at a time. I did a partial wire tuck on my 2nd Gen sedan. I think i am the only one so far. It is a big job don't need to rush to mess things up.
Old Jan 5, 2011 | 10:41 PM
856_reilly's Avatar
You guys think this can be done while the motor is out? My plan was to put everthing back together, put the harness on the way it went then start from there. do it then drop the motor in.. I think it would be easier this way since the motor is out and i can walk around the motor and have good access to all areas. What do you guys think? gonna be doing the headlights this weekend with my buddy Frank.
Old Jan 6, 2011 | 01:06 AM
I can't see it right now but maybe someone else can see it better. I think the problem w/ that is when it comes time to put the engine back in some of your wires will be short. Your going to be moving wires around and they might not reach the location your trying for.
Old Jan 6, 2011 | 01:11 AM
Frankieg35's Avatar
That's me!! Haha!!
Old Jan 6, 2011 | 08:03 PM
856_reilly's Avatar
lol.... Your funny as hell bro!!!!!!
Old Jan 6, 2011 | 08:08 PM
kennymo's Avatar
dont know when you plan to do it but me and g35papa are going to do my main harness in the next month or so and i plan on doing a full write up on that
ara777
Oct 25, 2017 01:45 PM
Vqalexisz
Oct 14, 2015 12:48 AM
Derekb
Sep 21, 2015 05:29 PM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
