Car is not a chore to drive anymore
So that "Wowowowowowowowowowo" sound while driving is bad wheel bearings? I heard this ever since I got my car. I just thought it had something to do with awd, as this is my first awd I didn't really know what to expect. Thought it was normal. It's not very loud at all, have to have the music off and air off to hear it. Been like that for a year, no bigger problems yet.
I had a front wheel bearing "hum" during turns when it was shot. The only bearing I have not replaced is the front passenger.
O YEA It's dangerous!
I do need a tranny flush and differential fluid changed though.
Sounds similar to tire road noise; with the new bearing the inside of my car is VERY quiet. It's nice hearing wind noise and people in the back seat!
You will need a slide hammer to take the hub out of the control arm/axle. Don't be afraid to rock that thing. Hahaha
If you google search "G35 hub assembly" and click "shopping" up top, you can find out sources of the bearings/hubs
Timkin is a quality bearing manufacturer and I would not hesitate to use them. They make OE wheel bearings on plenty of cars
http://www.google.com/search?q=G35%2...N&hl=en&tab=wf
I do not think Nissan sells it as one part, I've never seen a single part number for the two pieces.
Doesn't feel like a hooptie anymore! Suspension seems to work better, shifting is not rough, and turns are more accurate. I can actually hear my exhaust now!
I'm convinced now i need to do the fronts. Since it's 8 degrees out..i'll wait til spring. Still i want to get parts ready.
Few questions. WHo makes the OEM Nissan bearing? All i find are Timkin, and OEM nissan. Makes me think Timkin might make the OEM bearings for Nissan. Does anyone have an OEM bearing around? Any manufacturer stamp on it? There is a big price difference, so i don't want to spend $50-80 more for OEM to find it's a Timkin in a Nissan box.
Secondly...bearings are not side specific right? But they are Front and rear specific on an AWD right?
WHat about hubs? Can a front AWD hub work on the rear?
I was thinking of changing all 4 since the bearings are ~$60 each, but my press is 25 miles away at work. So after removing each bearing, id have to drive 50 miles to press in/out the hubs. Was thinking of buying a front hub/bearing assembly, installing that, and then buying just bearings only and pressing the hub out from the first bearing and using it on the other side and then continuing on to the rWould save me time. But if the front hubs can't be used on the rear, then my plan wont work.
Thank you for posting this - good to know.
