Car is not a chore to drive anymore
Old Jan 6, 2011 | 12:43 AM
AARONHL's Avatar
I replaced a worn rear wheel bearing yesterday. Feels like I'm riding on all four wheels now, shifting smoother, and turning tighter. No more WHOOO WHOOO WHOOO!!
WHOOOOOOOOHOOOOOO So glad I changed it, I like my car again. Should have replaced the bearing thousands of miles ago. Everyone should replace both rear bearings at 100,000!
Old Jan 6, 2011 | 12:44 AM
bluedevils95's Avatar
That's good to know. Glad you like your car again!
Old Jan 6, 2011 | 12:47 AM
AARONHL's Avatar
Yea, now that the wheel is actually turning and not wobbling!!!!
Old Jan 6, 2011 | 12:49 AM
Hotdawwgman's Avatar
That's cool... Great, job...
Old Jan 6, 2011 | 12:55 AM
So if the wheel bearing was bad and rubbing, would the mean that he's getting better gas mileage? hahaha
Old Jan 6, 2011 | 01:13 AM
Dacket84's Avatar
^^ Increased his HP too
Old Jan 6, 2011 | 01:33 AM
AARONHL's Avatar
Car feels peppier and I can already tell I'm getting better gas mileage!!!
Old Jan 6, 2011 | 01:36 AM
AARONHL's Avatar
It's like driving with the brake on...
Old Jan 6, 2011 | 01:38 AM
I bet that wheel bearing freed up like 20HP.
Old Jan 6, 2011 | 01:45 AM
AARONHL's Avatar
It's possible..
As soon as I took the axle off and spun the hub I realized the bearing was SHOTTTTT. It was grinding badly, too bad I had to take the axle off to find out for sure.
Old Jan 6, 2011 | 01:47 AM
AARONHL's Avatar
The transmission isn't a slopbox anymore; need to change my fluids soon.
Old Jan 6, 2011 | 02:03 AM
Well again, glad you got it fix and enjoying your G again.
Old Jan 6, 2011 | 08:20 AM
Mustang5L5's Avatar
I suspect i have a failing wheel bearing or two...prob is, i can't ID which one? I actually think it's the fronts, but these are pricey on an X. I need to do some more investigating because as of right now, i'm not sure enough.
Old Jan 6, 2011 | 08:51 AM
DivZero's Avatar
Does grabbing a wheel spoke and pulling back and forth work as a test for bad wheel bearings on the G?
Also, bad bearings can result in wheels falling of the car. They should be replaced immediately. Glad to hear you're safe again.
Old Jan 6, 2011 | 10:13 AM
Dacket84's Avatar
So that "Wowowowowowowowowowo" sound while driving is bad wheel bearings? I heard this ever since I got my car. I just thought it had something to do with awd, as this is my first awd I didn't really know what to expect. Thought it was normal. It's not very loud at all, have to have the music off and air off to hear it. Been like that for a year, no bigger problems yet.
I do need a tranny flush and differential fluid changed though.
